Question about Konica Minolta bizhub 180 All-In-One Printer
How to fix error c0f32 in konica minolta bizhub 180
    Sniper:
  • 108 Answers
Faulty TCR Sensor
• The measurement taken by the TCR sensor (TSRS) at a
time 2.0 sec. after the main motor (M1) has started turning
is less than 5% (greater than 4.63 V).
• The measurement taken by the TCR sensor (TCRS) at a
is 19% or more (1.41 V or less).
I would start with checking the TCR sensor located on the developing unit. Make sure it isn't caked up with toner. After that I would replace the developer and then the sensor. Check the developer unit for any damage to gears and seals.
Posted on May 17, 2010
2 Suggested Answers
  • 6 Answers
SOURCE: how to fix error c0f32
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Posted on Apr 09, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta buzz 211 printer error c0f32 ?
Off-on and press the stop bottom :) its trouble reset
Aug 23, 2015 | Konica Minolta Office Equipment & Supplies
How to clear error code c0f32 problems by minolta Di152
replace the developer and drum , clear counter and run F8
Mar 24, 2015 | Konica Minolta Bizhub 180 Di 152 152f...
Konica minolta b163 has this code cof32, how to take it out?
Hi
I have found your problem here:
Error Codes Konica Minolta bizhub 163 Code C0F32
and it says:-
Code:- C0F32
Description:- Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Remedy:- 1 Check to see if developer is available. 2 Check the ATDC Sensor connectors for proper connection and correct as necessary. 3 Change UN1. 4 Run ?gATDC Auto Adjust. 5 Change PWB-A. 6 Change PU1.
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Konica Minolta Office Equipment & Supplies
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Konica Minolta bizhub Di1811p i get error code C0F32
Need to replace the developer and drum and run required F8 and clear counters prior to the developer and drum replacement
Dec 05, 2008 | Minolta Office Equipment & Supplies
Konica Minolta bizhub 180 All-In-One Printer Logo
1,468 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
