Question about HP DeskJet F380 All-In-One Printer
Printer is telling me i have alignement problems
I recently installed a new ink cartridge and the printer is telling me that I have alignement problems. Haven't used the printer in over a year but everything is the same as the last time i used it.
black with a scannerand it is a rectangle
    Novelist:
    Scholar:
  • 125 Answers
Anytime you remove the cartridge the printer wants to align the print head. It doesn't matter whether you used it or not as long as you change/remove and/or install a new or old cartridge, it will ask to align. If you are printing text only and no pictures, then usually alignment is not critical. Though from experience, it is but usually 9 times out of 10 I don't need to re-align. But if you want to print pictures then you must align.
Posted on Apr 23, 2008
I have a Lexmark x6170 all in one printer. I have never had any problems until recently. I bought a Toshiba laptop and installed my Lexmark. I purchased new cartridges from Staples Office Supply and...
Run the printer software to do an "alignment" -- basically, it prints one page,
and then you scan the page, and the printer reads the printed page, to measure the "offset"
from where the BLACK versus the COLOUR ink prints. It will then electronically adjust the printer.
May 14, 2011 | Office Equipment & Supplies
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
    Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
    1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
    2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
    3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
      • Insert the tri-color cartridge into the left slot.
      • Insert the black cartridge into the right slot.
      Figure 4: Insert the cartridgec01107117.jpg
    4. Close the cartridge door.
    Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
    1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
    2. Press OK. The product prints an alignment page.
    3. Place the alignment page print-side down on the scanner glass.
    4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
    NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
    Sep 13, 2010 | Office Equipment & Supplies
    Black not printing
    Canon Bubble Jet i560 Ink Jet Printer not printing black
    Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
    The black ink doesn't print. We have brother cartridges in our printer DCP 385C, and until recently it always told us when ink was running out. now it doesn't print the black ink at all and it doesn't tell...
    Make sure the protective tape covering the new cartridge has been COMPLETELY removed then reinsert. Your printer should tell you that a new cartridge is inserted and ask to print a test page, align etc. Otherwise your cartridge may have a faulty chip which simply wont read.
    In which case you need to return it and get a replacement.
    Mar 07, 2010 | Brother DCP-385C Stylish Colour Inkjet...
    I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
    1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
    2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
    3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
    4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
    5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
    Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
    Printer Alignment Failed in HP C5280
    You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
    This is how HP makes their money.
    Jan 18, 2009 | HP Photosmart C5280 Printer
    My printer is new and jus instal a new ink
    you need to align the cartridges whenever you install the new cartridges and/or you install the printer.
    Go to Start >> Printers and Faxes >> Select your printer
    Right Click on the printer and click on Services Tab and
    Press
    "Align the Print cartridges"
    Make sure the Printer is turned on
    it will Print one Alignment Page
    Choose the best aligned option and Select on your Computer Screen
    I hope this will solve ur problem
    Best Of Luck
    Dec 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Question: Did you align it? And does it print ok?
    Mar 16, 2008 | Dell 924 All-in-One InkJet Printer
    HP DeskJet F380 All-In-One Printer Logo
    263 people viewed this question
    Seeker5211
    Seeker5211
