Question about Exercise & Fitness
I need key for ifit 835QT - Exercise & Fitness
    President:
  • 832 Answers
Call Icon Fitness@ 1-800-999-3756
KEY/CLIP part# 119038 cost $2.35
Posted on May 18, 2010
I purchased the preform 1110e ellipitical it has the monitor for ifit my wifi will not pick up the connetion to the ifit on my ellipitical why
https://ifit.zendesk.com/hc/en-us/articles/201881134- WIFI Requirements for WIFI Built in Machines
here are some requirements for your machine to connect to WIFI. If you are having connection issues, please read through these requirements, and tips to troubleshoot and resolve your issue. If you are unsure of any of these settings, please refer to your ISP(Internet Service Provider), or router manufacture for support.
  1. Broadcasting in 802.11 G/N
  2. Broadcasting Publicly
  3. DHCP Enabled
  4. Mac Adress Filtering Disabled
In most cases, the main cause for your machine not to connect is an incorrect WIFI password. If you have not changed your password, it is usually located on the bottom of your router.
Setting up iFit with built-in WiFi Setting up iFit with built in WiFi
This console is very easy to set up and use. If you have a router that has the WPS feature, just press the button on the front of the router then in the information mode of your equipment choose the WiFi WPS setup.
Set your machine to display the Information Screen. On a treadmill press and hold the STOP button as you place the magnetic key. On a bike or elliptical check in your owners guide but you ususally press and hold the "hamburger" or calorie button.
Use the arrow keys to select WiFi normal then press ENTER.
This screen reminds you of the WiFi setup card that came with your equipment. It will be needed to enter a password for your router.
Select your router from the list.
If your router needs a password enter it using the overlay card to find the correct buttons.
You will be presented with instructions to go to ifit.com/connect to enter this token. You must log in first.
Enter the same token you saw on the screen and your equipment will be connected to iFit.
You can watch a YouTube video here.
good luck
Oct 03, 2014 | Computers & Internet
I have a Proform 415 CT. When I put the key in place i get a FF code. I've tried unplugging overnight but still doesnt work. How do I fix this problem?
iFit card had scrambled the computer memory. Their solution to replace in the iFit card slot and it would reset the computer memory on the machine.God bless you
Mar 23, 2013 | Proform Exercise & Fitness
I need to replace the walking belt on a Proform 835QT. Is there a how-to manual?
There is, but I\'m a tech who has to do it, and I very rarely see a how-to.
You have to loosen the rear roller all the way, then very carefully back out the bolts that hold the front roller in, but just enough to let it loose. If you pull them out all the way you\'ll spend an hour trying to get the frame lined back up.
If you think this seems like a pain in the butt, you are right. It is one of the most labor intensive repairs on a treadmill. Second only to replacing the walkboard.
Jan 15, 2013 | Exercise & Fitness
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
My reebok treadmill makes only three beeps when you hit the sensor buttons
Plug in power cord, remove key, hold down speed+ and stop buttons, replace key, release buttons, press stop once, press and hold speed + until max. treadmill will run to top speed (s9.80 should read out 11.8 to 12.5.) It took a couple of times to get this to work for mine, but now it is OK. If unit does not run after several attempts then the console is probably bad and will need to be replaced ($410). Get another treadmill ! If it does run the console may still beep - problem is with IFIT card. You can get rid of the beeps by opening the console and unplugging the IFIT cable from the computer card if you want.
Feb 06, 2011 | Sport & Outdoor - Others
My Reebok S 9.80 will turn on but when I push any button on the console it just beeps and does not respond. What does that mean?
yes - had to recalibrate it. Plug it in, remove the key, hold down speed + and the stop button on the console, while holding them down replace the key. release the buttons, then press stop once. then press and hold speed + until speed reaches max. unit should run and speed up to max. console should display max speed (s9.80 should read 11.8 to 12.5). It took me a couple of tries to get running but now it is OK. If after several tries the unit does not run then the console will probably need to be replaced ($410) - so get a new treadmill ! If unit does run then it may still beep. Problem is with the IFit card. You can get rid of the beeping by opening the console (unplug the treadmill first) and removing the cable that connects the IFit card to the mother board. Of course the IFit will not work but it will not be beeping at you. good luck
Nov 21, 2010 | Reebok T 980 Treadmill
C2155 treadmill 1 1/2 yrs old, Nordic track. Panel lights up when the key is attached, beeps a triple beep sound fast about every 15 seconds? Keeps beeping when any of the buttons are pushed and won't...
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Jun 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Hello there. You can get parts here. http://www.iconservice.com/CustomerService/partsPartsList.do?model=29948&modelName=PROFORM+835QT&version=0&company=11
If you have your manual the parts list in the book is the same as online.
Part #90 is the safety key.
Good Luck! Tim
Mar 24, 2010 | Exercise & Fitness
My Proform 8.5 personal fitness trainer will no longer work. when I attach the magnetic key, it gives its normal beep followed by a stuttering series of beeps that are a slightly lower tone. The treadmill...
Hello there, It seems that you have a stuck button or a problem with the ifit card area. Yes I know you probably dont use it but just listen. If you have the demo card for the unit try putting the demo card into the ifit slot and press it in and out a couple of times. This will sometimes correct this problem. If that does not correct it then you will need to replace the console or possibly disconnect the ifit section from the console itself. Either way you will need to remove the console.
If more info is needed please leave me a note here and I will get back to you asap.
Good Luck! Tim
Jan 10, 2010 | Icon Exercise & Fitness
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Exercise & Fitness Logo
48 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
