Question about Iomega 1TB Desktop USB 2.0 Hard Drive
Wrong power supply
I think i put the wrong power supply on my external drive and its blown the board inside is it replaceble
    Problem Solver:
  • 8 Answers
It is replaceable, but usually you can only get the parts from the manufacturer directly, so try to call iomega in you country, and ask them to send you a new board in that harddrive. But if they would really do so, is another story, you know, they would rather sell you a new one, than repairing your old device. But I'm not saying don't call them, by all mean please do, I may be wrong.
Posted on May 16, 2010
Power supply blown fuse on board
I would strongly recommend just buying a new power supply and not try to save a couple of bucks. If you touch the wrong thing inside you will be severely electrocuted and probably die.
Aug 19, 2012 | Apple (661-3184) (6613184) Power Supply
I plugged the wrong power supply (my laptop) into my Simpletech drive and couldn't figure out why just the power indicator flashed but nothing else happened. When I plugged in the right power supply...
It is worth a try. The circuit board of the SATA to USB interface inside the drive casing is definitely fried, but the drive itself could still be alive & usable.
Jul 12, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
My Buffalo external hard drive does not show-up as an icon on my screen but the power light shows green. It clicks 6 times when I power it up but then the drive inside stops spinning and a red light starts...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Sep 03, 2010 | Buffalo Technology DriveStation HD-HC500U2...
Wrong power supply
constact Iomege ! Tell them my HDD is not powering up . do not tell them that u did it . See if u can get replacement
Mar 24, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
St3500320as bios not detect,i am using it as external hdd, once i used wrong power supply (original 12V, wrong 19V)and after that it was no detectable  in bios anymore, i can see some places on board...
I'm not sure I understand you correctly but this is what I think.
You tried to use the drive in an external case and the power supply was 19v. The drive really needs 12v. When you put it back inside a PC the bois does not detect it.
Id say it is destroyed. Do not wast you time with it.
If you think it is burned then it probably is.
Sep 25, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
External disk drive (gradually) not working any more
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
Jul 04, 2009 | Western Digital (WD2500JBRT) 250 GB Hard...
External hard drive wrong power supply was plugged in
The power circuits in the external hard drive enclosure may have burnt out or the fuse may have blown. Its unlikely your hard-disk is itself damaged.
You may remove the actual hard-disk from the enclosure and put it in another and access the data.
All the best!
Jan 29, 2009 | Computers & Internet
Power surge on hard drive
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 04, 2008 | Maxtor OneTouch II external hard drive...
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
97 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
