Question about Car Audio & Video
I have a older power acoustic sub with all the input and output labels rubbed off and it keeps poping the two fuses on first contact and its in protect mode. i havnt even got it working
    Problem Solver:
  • 11 Answers
Sounds like u blew some componets in the amp or someone else did it for u man most likely a few transistors and a resistor r two
Posted on May 17, 2010
I have a polk subwoofer and I want to know hot to connect it to my onkyo Lst10 surround sound bar
There should be a input for powered sub on bar, will have black input, and be labeled. Or check your reciever for sub output.
Dec 12, 2014 | Audio Players & Recorders
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
I need to connect the sub to my denon amp, can I get a cable to do this?
It all depends on the subwoofer; powered, or not powered. Most receivers have a low level output connection, 300millivolts: via an RCA type jack, labeled Subwoofer Output. With some of older subwoofers, you connect your speaker terminals from your Denon, to the subwoofer. From the subwoofer, you connect the output terminals to your front speakers. For more infomation, please contact me at audioserviceclinic.com. Thank you.
Oct 31, 2013 | Audio Players & Recorders
Boston Acoustics subwoofer keeps cutting out
Some subwoofers have a turn-on delay circuit at the input to prevent "popping". Unless the input remains at a certain level, the delay circuit turns off the sub. The only solution I have found is to change to another sub that is not so protective
Apr 01, 2013 | Boston Acoustics ASW650
Boston media theater system 7000684 input plug broken
better idea .... set FM transmitter in your laptop & receive audio signal with FM receiver.
or" connect external EP socket.
May 28, 2012 | Audio Players & Recorders
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
get the manual and it will tell you on a picture. go to the manufactuers website and download the manual. i would fond it for ya but you didn't specify a make and model #
Mar 24, 2010 | Car Audio & Video
My power acoustic BAMF 2200 amp wont power subs
Check all of your connections, make sure your RCAs are hooked up correctly, and aren't pinched anywhere, make sure your subs are hooked up right, and making good contact, if the amp turns on and doesn't go into protect mode it should be alright. If you can't get it going, take it to an audio shop and have them test it...
Sep 17, 2009 | Car Audio & Video
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
Power acoustic ov1-30000 3000w gothic series
IT SEEMS TO ME THAT THE RADIO MAY HAVE A OUTPUT FOR THE SUBS OR REAR RCA CHECK RADIO MENU AND SEE IF THIS IS ON OR OFF
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
