Question about Samsung Washing Machines
SW80ASP SAMSUNG WASHING MACHINE
MY MACHINE SOMETIMES, WHEN IT GETS TO SPIN CYCLE, CUTS MY POWER?SOMETIMES IF I SHAKE AND JIGGLE THE HOSE OR MACHINE, THE NEXT SPIN CYCLE WILL WORK, OTHERTIMES I HAVE TO LET IT DRAIN, THEN THE SPIN WILL WORK ON THE NEXT CYCLE
aborcass
  • 2651 Answers
SOURCE: washing machine
place it in spin do you hear it runnig at all???lift the top real quick to tell if its moving. if motors runing but kinda sounds loud and ratchety, like something broken. you probably have a bad motor coupling. part number 285753a
Posted on Mar 02, 2008
  • 26 Answers
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Posted on Dec 20, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
pic498
  • 32 Answers
SOURCE: WILL NOT DRAIN OR SPIN AFTER WASH CYCLE HAVE TO JIGGLE DIAL
could be the timer or possible the lid switch. push your finger in the hole where the lid switch is and you should heard an audible "click". If it doesn't click then that's probably the problem.
Posted on Jul 20, 2009
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Can not keep the HE 3 washer from jumping around on the spin cycle. Floor is level and machine is level with legs locked in place. Have lowered leveling legs to the base and locked them tight with the...
these machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Sep 24, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine fills up with water and continues till you stop it yourself. Also if you try to turn knob to agitate the cycle it wont . It will go to the spin cycle if you manually take it there. Hoping...
lol, no It's not the motor. The motor drives the spin cycle, so it's fine.
Unplug the machine!
Now about the water filling continiously. Look for where the water level switch is located and open the machine to look at the back of that switch. there should be a hose connected to the back of this, sometimes it becomes DISCONNECTED, sometimes it gets chewed on by a mouse. if the hose is connected on that side feel along the hose to see if it is broken or chewed up, if it is, replace the hose. If not replace the water level switch.
It's important to note that If the hose were disconnected at the other end water would be all over the floor as soon as the machine started to fill up.
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Samsung washing machine SW80ASP and it's often flashing err 7 and not finished the cycle when I go to get the washing out. It also seems to take much longer than usual on economy cycle. thanks
Hi, the code book points to a control error or malfunction. this normally means the control board is malfunctioning and will need a break point test preformed to find the specific issue at hand.
please rate and god bless.
Mar 16, 2009 | Washing Machines
Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Jan 16, 2009 | Samsung SW62ASP Top Load Washer
I have a samsung P1453 washing machine and it refuses to spin, I have checked the obvious like filter and discharge hose,. Is there some sort of sensor to check for load in-balance
hi i also have a samsung p1453 that will not spin when the digital counter gets to 9 mins remaining it jumps back to 10 mins and wont go through the spin cycle the pump is working fine and emptying as it should cann ot see anything blown on the pcb
any advise woulkd be appreciated
May 14, 2008 | Washing Machines
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
