Question about Hoover F5870-900 SteamVac Vacuum
Hoover 6500 will turn on
Hoover 6500 will not turn on is there a fuse to check?
SOURCE: hoover steam cleaner cleans but no longer suctions up the mess
My Hoover is not sucking up the water? Why?
Posted on Sep 24, 2008
ukvacfan
  • 328 Answers
SOURCE: Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Posted on Mar 06, 2009
galati2k
  • 281 Answers
SOURCE: how to switch from tools to floor
THERE SHOULD BE A KNOB ON THE SIDE THAT YOU TURN IT WILL SAY FLOOR AND HOSE TURN IT TO FLOOR
Posted on Apr 11, 2009
  • 61 Answers
SOURCE: hoover steamvac f5899-100 died, will not come on.
There is no fuse on a hoover steanvac, but it may have a ac/dc converter. I do not have a model list in front of me but if it does then this probally went bad. Another option is it may have overheated give the machine 12 hours to reset internally and try it again.
Posted on Apr 16, 2009
SOURCE: hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Posted on Aug 30, 2009
Hoover Wind Tunnel got plugged and very hot. We cleaned it out and now it won't turn on. Any ideas?
Thermal fuse failed, motor brush gear stuck, switch failed, power cord...
You will need to dismantle it and check the circuit with a meter...
Nov 15, 2017 | Hoover Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Hoover steamvac f5899-100 died, will not come on. is there an internal fuse i can check?
Apr 14, 2009 | Hoover F5899-910 SteamVac Vacuum
How to switch from tools to floor on hoover widepath 6500? no manual
Apr 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover vacuum turned off and wont go back on
Generic problem for all Vacuums
Hoover vacuum turned off and won’t go back on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
Not knowing the model number – or if it is a canister or upright --- you may have a defective switch and would need to replace it – check with you local vacuum cleaner dealer in your area or in the yellow pages or call the Hoover Co for further assistance
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 21, 2008 | Vacuums
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F5870-900 SteamVac Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
