Question about Electrical Supplies
Water found in the kerosene fuel pump model ebk 1000and so cannot start and operate
  • 5,603 Answers
Kerosene unfortunately absorbs water.
You will have to purge the whole fuel line and system and then bleed the lines as you would brake lines by disconnecting at the injector. Make sure you get ALL the water/fluid out of the tank before putting clean fuel in.
Posted on May 17, 2010
I have a 35,000 btu Reddy heater that won't fire at the spark plug but is getting a signal from the magneto. Is the magneto bad or does the spark plug have to be in the mist of kerosene to spark?
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Mar 07, 2013 | Reddy Heater-30-55,000 BTU Variable
Heater would not start this morning It tried for a second and then just would not ignite. it was running fine yesterday
Take the top cover off of the unit. Plug it in and look at the ignitor for a bright glow or spark, depending on your ignition source. This should happen before the fan starts. Once the fan starts you should be able to see fuel spraying out of the spray nozzle. If there is no fuel, check the fuel screen, air output from the pump, air filters on the pump, and the correct air pressure from the pump. The nozzle can also be dirty. Check for air leaks on the pump by spraying soapy water on the pump while the blower fan is running.
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
E13 for a 2200 Monitor heater
E-13 - No ignition. Water in fuel line, no fuel in sump, blocked pumpand/or sump filter. the pump doesn't know water from kerosene it will pumpthis. Water doesn't burn so it will knock out the flame and lock out theheater. You can add a quart of denatured alcohol to 150 gallons of kerosene.the alcohol will emulsify the water enabling it to burn.
THERE'S A RED BUTTON THAT RESETS THE FLOAT. press this down. All it does isrelease the float. There's a sheet metal tab on the float and a magnet on thebottom of the button
Jan 11, 2011 | Heating & Cooling
Water found in the kerosene fuel pump model EBK 1000and so cannot start and operate
Kerosene unfortunately will absorb water. This was a major problem when they started using jet engines. They had some accidents due to water in the fuel. Now they have driers in line for fueling.
You need to purge the whole fuel system and use new clean, dry fuel.
Mar 24, 2010 | Honda Electrical Supplies
Hi, our black 3ebk will not print. we have deep
Check if there is a tape over the top vent intended to let air into the ink tank and so ink can flow out to the writing head.
Sep 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Water in the fuel tank wrangler 97
Sorry the isn't a drain plug on the fuel tank. Try this go to walmart or home depot and buy a kerosene can hand pump plastic cost $3 to $6 remove the hose coming from refill to tank cut off a piece of old water hose approx.5ft insert into tank from opening insert hard plastic portion of hand pump into water hose have something large enough to contain the fuel and start pumping open valve on pump to release pressure may have to pump several times to get it flowing good do not try to **** on hose pump will work once all gone reconnect hose and refill fuel with one bottle of Lucas fuel treatment and one bottle of Marvel Mistery Oil drive it all out refill fuel again with one last bottle of Lucas fuel treatment. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 22, 2009 | 1995 Jeep Wrangler
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Won't print black
just try with tet page of printer and also reinstall the driver and see. bye
Sep 26, 2007 | Epson Stylus Color 740 InkJet Printer
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
