Question about Amana BC21V1W Bottom Freezer Refrigerator
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: loud humming noise (vibration) from freezer
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Posted on Mar 24, 2010
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Knocking noise in refrigerator section
This will be a loose mount on the electric motor (tighten)
May 05, 2010 | Amana ABB1927DE Bottom Freezer...
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
We have a amana BX21VW bottom freezer refridgerator. The fan behind the back plate in the freezer section makes a very loud vibrating noise. If we put pressure on it it is quite. How can we fix it?
Good day,
There is no repair possible. You could try changing the blade only, but the best repair is replacing the motor and blade as a unit.
However, it is your choice on the blade only approach.
Feb 25, 2010 | Amana Refrigerators
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Oct 01, 2009 | GE GSS25JEMWW Side by Side
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana bottom Freezer Refrigerator
Fan motor probably iced up, turn off defrost for 24hrs with doors open turn back on and should be working within 24hrs. Regards Advisor
May 14, 2007 | Amana ABB1927DE Bottom Freezer...
Amana BC21V1W Bottom Freezer Refrigerator Logo
172 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
