Question about Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series
Toilet makes a loud noise when filling - Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series
2 Suggested Answers
  • 1026 Answers
SOURCE: toilet makes a loud noise when filling
the valve on the ballcock needs changing to stop it singing as w call it here
Posted on Mar 24, 2010
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
My toto toilet flushes and refills fine, but it just started making loud noises when refilling. The noise stops when the tank is full
Your fill valve is going bad it can be replace with a new fluidmaster instead of the Ultra-G you have in it its going bad they do over time you may want to check your house water pressure in case that may have been what broke it you don';t want to break a new one.
Aug 29, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
Handle is sticking in one toilet the other toilet makes a loud whisteling noise after flusing
The handle is probably worn out on the first toilet. The whistling on the other toilet is probably from a restriction in the fill valve, if you can live with whistling, it's not really a problem. If not, I recommend trying a different type of valve.
Aug 09, 2011 | Toto Home
I have the k-4620-da toilet and when we flush a loud noise starts from inside the tank and doesn't stop until float is all the way up!
Make a note where your water level is then the tank is full. Replace the assembly that lets the water in with a Fluidmaster 400A fill valve, available at your local plumbing supply store.
Sep 27, 2010 | Kohler Home
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
May 07, 2010 | Neptune FB1602 Roma Elongated Front Toilet
Noisy fill valve
You may have higher than normal water pressure. Try closing the the cutoff valve on the wall half way and see if that helps. You can experiment with it till you find the best position. You can get a pressure gauge that will attach to a hose bib for a few dollars to see if the pressure is too high (more than 80 psi is too high). If it is too high you can have a plumber install a pressure breaker on the line where it enters the house.
Apr 02, 2010 | Toto C743s-03 Drake Ound Toilet Bowl Only...
Mar 24, 2010 | Sloan M-101526-F Flushmate?® Complete...
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series Logo
178 people viewed this question
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
