Question about Amana ALG643RB Gas Dryer
Alg643raw gas dryer
Dryer was running my wife opened the door reclosed it and now the dryer wont start
  • 709 Answers
Try unplug and plug back in first let it reset and if that dont work, check thermal fuse may be blown..the fuse located in the back next to the fan in the housing. If fuse blown unit not work, if you go to www.appliancepartspros.com choose your model and it will give diagram of location termal fuse. check fuse first make sure is blown before you order it.
Posted on Jul 09, 2009
SOURCE:
Whirlpool duet gas dryer is not working. The lights on the control panel are on. My husband has replaced the thermal fuse, thermistor and the motor. Still will not run. Please help.
check the door switch,if this switch is bad dryer wont work,this is a spdt type switch as it runs the drum light when doors open and lets machine start and operate with door closed
May 06, 2012 | Whirlpool Dryers
Dryer won't turn on
touch the door swich and see if it clicks when you push in on it,if that is good you'll have to check thermal fuse that is located either on blower wheel housing or in back of dryer,check to see if belt broke some dryers have switch that kills dryer if belt breaks
Nov 03, 2009 | Kenmore 73932 Gas Dryer
I opened the door on my ge dryer to ceck the cloths, when i shut the door and turned the dial to start it again it would not come on.. What is my problem??
It's likely the door switch broke when you reclosed the door. If the dryer still thinks the door is open it won't start.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model is always helpful when requesting information.
Aug 23, 2009 | Dryers
I have an Amana Gas Dryer Model # ALG643raw
Sounds like the flame detector sensor may have failed, but you really need a multimeter to test the components in the circuit to make sure you replace the right partt
Aug 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Sears Gas Dryer won't run
sounds like you have a bad fuse. does yours have a kick panel? sounds like you have a bad timer and fuse.
Jun 01, 2009 | Kenmore 74602 Gas Dryer
Kenmore 110 66862501 won't start
Do you mean you checked the outlet and breaker and that wasn't the problem, or you have no power there? I can't imagine anything the servicer did that would have required shutting off the power, only to unplug the dryer. The door switch probably isn't working still and the machine won't run because it thinks the door is open. Call the servicer back to check. You should be covered by some kind of warranty for the repair parts and labor.
May 21, 2009 | Kenmore 70172 Gas Commercial Dryer
Maytag Legacy Series Dryer will not start
Welcome,
Your temperature is to high and running wild . So the system has shut it down for safety reasons.
You need to call service for a diagnoses
if you do get it running, do not leave it unattended or better yet do not use it as is!
Send me the model number and I can send you the schematics!
Thank You for trusting us with your questions.
Huum
Please remember to leave a solved rating before you sign off!
Dec 22, 2008 | Dryers
Magic chef dryer
hi there,
she may have tripped the house breaker. unplug the machine and check the breaker on the house electrical box. plug the dryer back in and see if that will work.
Sep 30, 2008 | Dryers
Amana ALG643RB Gas Dryer Logo
175 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
