Question about Sanyo VPC-E760 Digital Camera
How do I correct my camera when it says lens ERROR21
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
    Sergeant:
  • 420 Answers
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
Lens won't open when camera turned on says lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 19, 2011 | Nikon Coolpix S3000 Digital Camera
Where is the reset button on the powershot s3 IS
"Lens error, "Restart" camera", means to try turning the camera off and on to see if that corrects the problem. Unfortunately, it rarely does.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 29, 2010 | Canon PowerShot S3 IS Digital Camera
Have got lens problem they are asking for restart the camera but don't no which one is restart button :((
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. A simple "restart" (turning the camera off and on) rarely corrects this problem. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 14, 2010 | Canon PowerShot A480 Digital Camera
Lens error
May 31, 2010 | Canon PowerShot A560 Digital Camera
Lens error21
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 26, 2010 | Kodak DCS 330 Digital Camera
Lens error Lens error message on the back of camera, The lens keeps going in and out.
Apr 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Lens Error restart camera error put in new batteries lens won't retract camera is locked
Mar 27, 2010 | Canon PowerShot A560 Digital Camera
HOW DO I CORRECT MY CAMERA WHEN IT SAYS LENS ERROR21
HI there try to reset the camera from menu & then setting option. After that turnoff & again turn on . Now try for click an image. If you face the same problem then the error message show is the right cause. Its mena the lens guide pin is damaged or dislocate. Replace or repair that . Thanks & waiting for your feedback,
Mar 24, 2010 | Sanyo VPC-E760 Digital Camera
How can I correct my lens error on my A835 digital camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 16, 2010 | General Electric A835 Digital Camera
Camera lens
This is a simple one. The lens is tilted at an angle. Most likely you will find your lens cap doesn't fit correctly and all you need to do is align the lens correctly. Then when you turn on the power, the lens will autmatically extend.
Jan 11, 2008 | Kodak EasyShare Z7590 Digital Camera
Sanyo VPC-E760 Digital Camera Logo
29 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
