Question about Emerson MW8108P Microwave Oven
Blower fan for solderable reflow oven not working contineousley
Blower fan for solderable reflow oven is not working contineousley after rotating some time it stop rotating and after some time automaticaly it starts rotating what is the problem can yo please give me feedback quikley its urgent .
    Champion:
  • 225 Answers
Check the control bord, and blower fan.
Posted on Apr 08, 2008
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
How do you change fan exhaust from wall to front of unit.thanks
physically pull up and rotate exhaust blower fan assembly so it points toward the front. you'll need to remove a plate with a common phillips screwdriver.
Aug 06, 2011 | Goldstar MV-1501 Microwave Oven
Food cooks uneven with the fan running and has to be rotated to ensure even cooking
Remove the mains plug , remove the glass plate and roller from the cabin , open the top covers and the rear covers to check for the drive and belt to the rotating table stem. If this is worn change, if not check the motor and the drive to the motor. Check on the main processor board for any loose connections or dry soldering.
Apr 15, 2011 | Microwave Ovens
Converting the vent fan on a GE Combination Oven
is your house vent connected properly? no restrictions?
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave doesnt heat, power is on fan is working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
klgjlgk
Jul 06, 2010 | GE JVM1540SMSS Microwave Oven
Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
May 25, 2009 | Goldstar MV-1501 Microwave Oven
Fan vents
Most microwave oven fan systems can be rotated for either back or top venting.. This can be done by removing a few screws and rotating the blower housing to the position you need and screwing it back in place.. Hope this helps..
Aug 30, 2008 | GE Microwave Ovens
Concerning Microwave oven Model MH2175XS I am following the installtion instruction phamplet to change the vent fan from inside circulation to outside by removing the two blower screws on the back and...
Looking at the pamphlet, it sounds like you're doing everything right.
It sounds like something is a little bent or out of alignment making it stick.
Maybe you can take the tip of the screwdriver, and push against the motor assembly a bit to loosen it?
Aug 11, 2008 | Whirlpool Microwave Ovens
Goldstar MV1501BQ no heat
Hi LMGreen! Sorry for the late response a bit busy at work.. Coming back to the problem..
Solder joints on power control board are cracked and/or burned. Inspect solder connections on power control board for deterioration. This usually occurs where the harness connector is mounted to the circuit board. Reinforce and re-solder as necessary. Also check all other solder joints.
Apr 19, 2008 | Goldstar MV-1501 Microwave Oven
Blower
check fan motor and related circuit.,control panel circuit also check..
Oct 01, 2007 | Maytag MMV4205 Microwave Oven
Emerson MW8108P Microwave Oven Logo
136 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
