Question about Gateway FPD2275W LCD Monitor
Dell 1503FF flat panel monitor is blank
I have a 2001 Dell 1503FF flat screen that has suddenly gone on the fritz -- it shows two green LED lights in the lower right corner of the frame next to "1" and "2", the power switch won't light up at all and the whole screen is blank. I've tried totally disconnecting the power and computer cables, turning off the computer and reconnecting everything, then turning it back on, but the situation remains the same.
  • Mavi-NB Jun 03, 2008
    As soon as current fails or plug is pulled out Monitor Dell1503FP does not start when current is on again, remains black. The two green lights on the right light up, but not the power green light. Restarts sometimes after several times disconnecting from mains.
    Now monitor is lit, but the first green light (from left to right) is lit. Please give some advise and please explain the meaning of that commands.
  • 180 Answers
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Posted on Apr 20, 2008
SOURCE:
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Dell 1702FP 17" Blank Screen Problem
Try it on another computer, if it works the video card moght be dead.
Jul 11, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
133 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
