Question about Maytag MAT13MN Top Load Washer
Washer tub goes off balance every time and washer walks!
Washer tub off balance. washer walks
  • Tbayer Apr 24, 2008
    Every time we wash clothes our Maytag washer goes out of balance during the wash cycle. We then cut the wash cycle short and move the dial to rinse to finish the load. Is this easy to fix or is the washer a goner. The wash is only 5 years old and looks great.
    Problem Solver:
  • 18 Answers
There may be a possibility here of the centre hub being worn or the liner tub bearing being worn due to the age of the machine.. here is a list and diagrams of the parts you may need and can get from here:-
http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=mat13mn&searchTerm=img_CW17-6&RefineSearch=0&imgMfg=Maytag
try to check for slackness when the tub is empty causing a rocking/slapping motion whilst empty. if the tub is used regularly and to its maximum capacity then the likeliehood is these bearings/hubs may need to be replaced.. the "walking" across the floor will be accented by the amount of items plus water in the tub. and if the tub is off balance,then this will be more highlighted when also full of water and items... if you feel this is over the top,then try to lighten the load that is in the tub at any given time. this will determine weather the bearing has indeed worn .the lighter the load,the less "walking the machine should do in cycle.. the only time walking would be unchanged is during the spin cycle,when the speed is of a constant one and it will vibrate at the same rate. placing it on a rubber mat is not a solution but just something that will make you hopefully think it is solved
and you may as well just bolt the machine to the floor and hope for the best
Posted on Dec 27, 2008
Top loader Matag LAT9605aae shakes and goes out of balance but not enough to cut out.
It is not walking.
Posted on Dec 06, 2008
Place the washer on a rubber mat. I got one from the automotive department at the walmart and it stopped my walking.
Posted on May 08, 2008
Model #GLWS1439FS1, Washer vibrates and walks, Washer is on concrete floor and has been leveled numerous times. Purchesed in Feb '08 and this problem started about 4 months ago.
Good Afternoon, Mayconst:
The quick and dirty method is to head for the local dollar shop for some furniture moving pads or sliders, but that won't stop the damage that caused the machine to walk in the first place. That leave the slow and dirty method.
First, does the machine 'walk' every time you do the wash, or just when there are heavy items in the load? If your washing machine has a liquid filled balance ring at the top of the tub, just under the lid, it will not work if it has cracked and leaked out all of the water in it. Has something gone over the side of the basket like coins, sneaker parts (yes, it happens) or brassiere wires?
Lift the washer lid, check the balance ring. If you have a construction level, place it along the edge at the front of the machine, then at the side. If the bubble is not in the exact middle on both axis, twist up (or down) on the support feet until it is. It may be as simple as sliding a furniture moving puck under the offending foot.
Go back up top, open the lid, and gently squeeze around the edge of the tub. It should give no more than 1/2 an inch, and spring back to center.
Good Luck!
Chr
May 30, 2011 | Frigidaire 3.0 Cu. Ft. Top Loading Washer,...
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer goes off balance so easily, no matter the size of the load, from towels to shirts. We checked the washing machine itself is level. It's so frustrating to have a small to medium load cause the basket...
The tub is out of alignment.The suspension springs are weak and must be tight, the tub must not shake,if so the dampers are faulty.
This suspension must be so rigid that it must not shake around freely . check the pulley arangement , the bearings at the bottom spindle, if out of balance. If there is any anomalies in this ddrive section it must be observed and checked.
A careful analysis is most important to having a first hand information.
Aug 23, 2010 | Maytag HAV2557 Top Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine balance is off since we moved it.
There are tension springs attached to the tub. They are for the balancing upon spinning. Check and see if one came loose
May 12, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer stays out of balance
most likely a spring has come off the tub base. there are three short horizontal springs that surround the tub connecting it to the tripod base and one long spring in the very back that connects the base to the bottom back. check these out and reattach if off.
May 24, 2009 | Whirlpool LSR5132PQ Top Load Washer
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Maytag washer pav2200aww walks
if i was you i would go down to your second hand appliance shop and ask them to have a look it should not cost much as they do that sort of thing all the time
Dec 30, 2007 | Maytag PAV2300 Top Load Washer
Maytag MAT13MN Top Load Washer Logo
1,531 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
