Question about Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor is black
Tried to adjust brightness of monitor and screen went black. Cannot get it to stay on.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
This laptop is newly brought, what i did is plug in the charger, turn on the laptop, while on the logging screen, the laptop screen suddenly went on and off and then finally, the monitor went blackout but...
Hello Xylla,
You have not mentioned which model of Alienware Laptop you have but, there should be reference to adjusting the brightness in the manual.
Try using <Function Key> + <F4> or <Function Key> + <F5> to adjust the brightness.
I hope this helps.
Kind regards,
Ron.
Oct 26, 2013 | Dell Alienware Computers & Internet
Compaq Presario CQ60 screen is black
also make sure you're not in presentation mode, my vostro (winxp) would randomly boot to presentation mode and turn off my monitor....
upgraded to win7 and it stopped doing it...
Oct 03, 2012 | Compaq CQ60-215DX Notebook
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Monitor is black
Replace the 2 1Uf capacitors on the power supply board. They are at the edge between the 2 lamp plugs.
Monitor Mike
Mar 24, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Screen is black, No Input Signal
my older monitor had a similar problem but instead of black its bright white and it keeps auto adjusting but not right it goes off screen. i still use it just not as a main monitor as it is old. erm see if its it warranty if it isnt then you probably need to get a new one
Jun 09, 2009 | HP W2007 LCD Monitor
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
