Question about Creative Labs ZEN V Plus MP3 Player
My Zen V Plus screen will not turn on, I have even tried the reboot thing, and i have tried resetting it, I dont know what to do, please help me.
Get a new zen... its obviously broken. Return it to somebody at the shop you bought it from, and you will get one just like it!
Posted on Apr 02, 2008
My Zen Vision M 30GB mp3 player won't turn on, the blue light at the top flashes but the screen won't pop up, not even when i plug it in to charge it (which it usually does automatically). Now, i tried to...
Mine does the same thing, You just have to leave it plugged in for a long time, and after a while the black screen with the battery that tells you it's charging will show up.
Trust me, it'll happen.
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
It is frozen and nothing works
all of you have the same touble may be due to a must need firmware upgrade youll find it on the maufactures website they will give much need help. But when it comes to an mp3 player i prefer a sony walkman.
Oct 30, 2008 | Creative Labs Zen Digital Media Player
Stuck in recovery mode, firmware problem
i have the same problem of recovery mode. can you help me please
Jul 12, 2008 | Creative Labs ZEN V Plus MP3 Player
My Zen Nano Plus 1gb turned into a Zen STONE Plus??
Most probable that either you have downloaded the wrong firmware, or the website has an incorrect link. Make sure u select the right 1 and try again, hope it works (ps, in the url at the top of the page, it should link u to a page that says summet similar to the model of your player such as www.website.com/download/nano.zip as an example...
Jun 08, 2008 | Creative Labs Zen Nano Plus MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
The button of my player Zen V Plus 4GB, the on and off switch loose
usually its 0000 or depending how many numbers. all zeros. just do a clean up. insert pin in reset hole while holding down power button, then let go, select clean up, let it sit and do its business, then when done, reboot
Feb 12, 2008 | Creative Labs ZEN V Plus MP3 Player
JUST CANT GET MY ZEN V PLUS TO WORK
I would return it but thats just me.
heres the fix
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
good luck
please mark the post with a fixya
Feb 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative ZEN v plus
did you try to reset it and do a disk cleanup?
Jan 22, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery Screen, take 2.
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Dec 27, 2007 | Creative Labs ZEN V Plus MP3 Player
Help please please please!!!!
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
if that doesnt work try this:
Dec 09, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
27 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
