Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57H81 We have a black rectangle almost the length of the screen on the bottom.
Do you know what format the picture is in? 16 X 9 wide, theatre mode, zoom, etc... And what type of signal source do you use? Never seen a problem on the bottom, but have seen Dish Network boxes that have an adjustment for left to right Horizontal. Maybe there is one with vertical adjustment for centering picture? Don't know just thinking of any easy solutions. Of course the closed caption solution is probably correct. If not post back and I'll get out the manual on cd.
Posted on Apr 01, 2008
    Sergeant:
    Champion:
  • 301 Answers
Check closed captioning settings in the menu
Posted on Mar 31, 2008
I have an older (about 10 years old) Toshiba 35
You some how have turned on the closed caption function on your tv, go to the tv's menu under closed caption an dturn it off.
Mar 22, 2010 | Televison & Video
Black rectangle on the screen
That sounds like the Closed Caption function is turned on. Go to the menu and turn it off if it is on.
Jul 29, 2009 | Toshiba 65H82 65" Rear Projection...
Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
Jul 11, 2009 | Toshiba 57H81 57" Rear Projection...
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Jun 16, 2009 | Toshiba 50HP66 50 in. Plasma Television
Black rectangle on picture Toshiba CF27H40
Hi
maybe your horizontal yoke is defective..
Thanks!
Feb 25, 2009 | Toshiba CF27H40 27" TV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Black Rectangle appears on bottom half of screen
Go into your setup menu and turn off closed captioning. The box is there for some channels even though no text is being sent. If you need to keep the closed captioning, try selecting a different mode for it.
Sep 15, 2008 | Toshiba 24AF43 24" TV
Toshiba 57H81 Color Problem
sounds like your green tube is set to high.
take the front cover off and the plastic cover under that
you will see a black box about 6x6 with 6 controls one is for focus the other is for intensity
here a guide for sony but yours should be close.
Mar 14, 2008 | Toshiba 57H81 57" Rear Projection...
Picture moving from top to bottom
you have a defect in the vertical circuit. most likely the vertical chip ,caps,diode and supply voltage for the chip..john
May 28, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
