Question about Honeywell Cool Moisture HCM-560 Humidifier Humidifier
Are filters still available?
I need more filters and can't seem to find them at any of the large home improvement stores. Does anyone know if they are still available? If not, does anyone know of another brand and model of filter that will work in the Honeywell HCM-560 unit?
Thanks!
  • 123 Answers
You are looking for replacement filter HAC-504. (which is the filter for the 500 series)
You can order them from Homedepot.com
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100035531&langId=-1&catalogId=10053&ci_sku=100035531&ci_src=14110944&cm_mmc=1hd.com2froogle-_-product_feed-_-D27X-_-100035531
Hope this helps.
Good Luck.
Posted on Apr 18, 2008
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
I need the air purifier filter for a danby dhcc6020
You may be able to use filters from the stove overhead filters.Stove suppliers sell filters which can be cut to size.
The filters are usually the same as those used for air conditioners.
Feb 02, 2013 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I NEED A O RING ON MY 3100 MODEL WHERE WILL I FIND ONE
auto parts store or a home improvement center, you can also try a air and heating distributor that sells parts and services
Aug 28, 2010 | Vicks V3100 1.2 Gallon Humidifier
Vicks V-3100E Filters
Here is a site that stocks the filters you require, but needless to say it is main order.
http://www.healthcare4all.co.uk/vicks-filter-aca3e-v3100-p-330.html?osCsid=168dab22ab1bfeb75a4095d3d6e51127
Vicks Kaz Filter ACA-3E for V-3100
Availability: In Stock (for immediate despatch)
[ACA3E]
£9.79
(incl. VAT at 15%)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Vicks V3100 1.2 Gallon Humidifier
Filters
you need filter model hwf100 for that unit. now you can try at any local hardware store or if your in canada you can try at canadian tire ifyou want. but if you want to order them offline you can go to www.appliancefactoryparts.com. type in your model number, clickon the picture scroll down alittle and the filters are the first thing to see. if you have any other questions please let me know.
Feb 21, 2009 | Holmes Products HM630-U Humidifier
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Hunter humidifer
I dont know why your humidifier is spitting water out.
But it sounds like you need to clean the unit and install a new filter. Once the filter becomes used, the humidifier won't work as well. Less water will be used because the clogged filter can't hold as much. Once you replace the filter, your water consumption should go back up and you should feel a difference in your home again.
Good Luck.
Feb 15, 2008 | Hunter 33201 Humidifier
Aprilaire 400 - Mesh Screen not wet
Not happy either. I bought 3 Aprilaire 400 for my house (3 zones). I picked this style since I have attic installation and did not want to run drains. The first night I expected a major air quality improvement but no change in humidity. I have installed humidifiers before so I know the drastic improvement they make. So I watched for a season and still no humidity improvement. Absolutely nothing at all. Same exact observation as you all described. Only the bottom of the media was wet. I'm dissatisfied with Aprilaire 400. Do not buy! Since I installed humidifiers before and understand them I am converting the Aprilaire 400 to work like a Aprilaire 600. I simply unwired the float sensors, removed the floats/lid and using a knife cut some of the plastic cups so the water would drain well. I also cut open the plastic exit port some too so it wont clog from dust globs. I obviously added drains. HUGE RESULTS. On the very first cycle on the humidity in that zone went from 25 to 48. I am watching carefully. -GK
Dec 31, 2007 | Aprilaire 400 Humidifier
Kenmore 14416 Humidifier keep Showing CF on display.
Contact these guys and they should be able to let you know where to get a user guide. http://www.sears.com/sr/misc/sears/custs... unfortunately they dont seem to have them online - please complain to them in the hope they might make this available instantly Hope This Helps :)
Mar 09, 2007 | Kenmore 14416 Humidifier
Honeywell Cool Moisture HCM-560 Humidifier Humidifier Logo
210 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
