Question about Sony KV-32CS70 32" TV
HEllo All, I have a Sony KV-32CS76E TV and I
Hello All I have a Sony KV-32CS76E tv and I have been using it for 5 years without any problem. It suddenly broke down and its front led flashes 14 times then lights geern for a while after that it again flashes 14 times. I had a search on Net and found out that it is a back-end error for this model tv. I would be very gratefull if you kindly explain what is back-end error and what should have been the cause for this because I am very curious to learn the cause for this and which part of my tv might be broken. Thanks for your kind helps in advance
    Scholar:
  • 152 Answers
If I remember correctly, the back-end IC is on the A board.
It regulates 2 power sources, ( 9v and 5 v ) ?
Obviously they will not be there if the main sources to the board are not there, so you will need to monitor those.
The highest is a little over 100v, and there are others, about 20v, 11v, and 5v, I think they are marked om the board.
Posted on May 03, 2017
    Top Expert:
  • Sony Master
  • 74,468 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: SONY TV KEEPS TURNING ITSELF OFF!!
You have to take it in to get it fixed. Five blinks means AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Jul 04, 2007
ctf1800
  • 4402 Answers
SOURCE: sony KV-36HS20
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Posted on Jan 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: sony trinitron kv-36fs76u
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • 80 Answers
SOURCE: 3 flashes at my sony tv kv-29fx66k
you probably need new power supply diodes or solder connections, you need a qualified tv repairman to fix this.
Posted on Sep 15, 2009
Testimonial: "Thank you for your answer I will trie to repair the power supply and I will inform you about the result. danny"
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
MY WEGA SONY KV-27FS13 TV - HAS SOUND THROUGH CABLE BOX BUT NO PICTURE. I DONT KNOW WHAT CHANNEL TO SET IT ON- AND DO I PUT IN ON DIGITAL OR ANALOG?
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
Jul 23, 2011 | Sony KV-27FS13 27" TV
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
Does the sony KV-30HS420 TV used a lamp..if yes where to lacate it
the KV-30HS420 model is a CRT based set and thus has no "lamp". What is hte proble with the set?
Dan
Mar 06, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV - 36FS13 36" flatscreen
Hello MLD110368
I think, TV screen has white-balance failure thats why TV light blinks 5 times.
While living in Pakistan, I can't fix your TV there. In my point of view, it doesn't cost much and you should contact nearest Sony repair shop.
Apr 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron KV-32FS320 5 blinks
Sony KP53HS10 5 blinks
Five blinks means "Video out abnormality detection". Possible problem areas are as follows:
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32CS70 32" TV Logo
149 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
