Question about Lexmark X2650 All-In-One InkJet Printer
Printer error flashing 1 then E then C, after
Printer error flashing 1 then E then C after changing printer cartridge on lexmark x650 which installed correctly.
2 Suggested Answers
SOURCE: Printer error flashing 1 then E then C, after
Try turning of printer, disconnect from power, Now removing ALL Ink, clean both the cartridge, and where they go, make sure is real clean. Now replace them. Then reconnect Power, & turn on. Hopefully this will have reset the printer. If NOT then your printer for what ever reason has developed a fault, OR that new cartridge is incompatible for whatever reason, perhaps a refilled, or counterfeit one?
Posted on Mar 24, 2010
I have a lexmark x2695 and when I turn on the printer appear a flashing error "1 E C"
The EC1 error code indicates that the printhead ID is not valid. Open the printer cover and remove both your cartridges. Close the cover. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert one cartridge first and close the cover. Check for any errors. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
May 12, 2011 | Lexmark X2600 InkJet Printer
Brand new lexmark original cartridge is not recognised. error report' no cartridge'. all contacts cleaned machine dismantled and cleaned and reassembled. has done this before on occasion with refilled...
1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
2. Make sure the correct toner cartridge is installed for this printer model.
1. Check Lexmark for a list of compatible cartridges for your printer.
2. If the wrong toner cartridge is installed, remove it and install the correct one.
3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
1. Turn off the printer.
2. Reseat the toner cartridge.
3. Close the lid.
4. Power the printer back on and check the display.
4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
How to fix error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dellâ„¢ 964 or 966 Printer
To reset factory defaults on the printer, perform the following steps:
1. Press the down arrow button until Maintenance is highlighted and press the Select button.
2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
3. The printer displays a confirmation message. Highlight Yes and press the Select button
Note:
Some settings such as phone lists, time, date, and country are not changed.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
Printer error flashing 1 then E then C, after changing printer cartridge on lexmark x650, which installed correctly.
Mar 24, 2010 | Lexmark X2650 All-In-One InkJet Printer
Cartridge error 1203
or
Hope it will work for you take care all the best Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One InkJet Printer
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
  1. Turn the power OFF.
  3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
  4. If it does not, close and reopen the cover:
  5. Remove the color print cartridge.
  6. Close the cover.
  7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
  8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
  9. Remove the black print cartridge and reinsert the color cartridge.
  10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
  11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Lexmark x1185 cartridge error msg
Step 1). Try cleaning the gold contacts on the print cartridge and on the printer itself with a pen eraser and a little alcohol.
Step 2). Uninstall the printer software and reinstall it.
Step 3). If the above two steps fail try a new cartridge. If none of these solutions work there is an electronic problem with the printer and it will have to be professionally diagnosed or replaced.
Hope this was of some help to you.
George
Jun 01, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X2650 All-In-One InkJet Printer Logo
167 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
