Question about Mercury KVM800M Motherboard
Kvm800m amd2700 1 gig of 2700 shuts down at boot up
Hi i,m having the same problems as others but cant find the right answer I just put a kvm800m motherboard with the 2700 chipset and brand new 1 gig of ddr2 2700 to my origional ata hard drive it boots till the xp window pops up and it just re-boots over and over. any help would be greatly apritiated.
  • 152 Answers
Because your old motherboard and new hardware resource change over in windows xp so disble in cmos setup ACPI option
or if that have already disable so enble it .
if problem can't solve so reinstall windows xp
Posted on Apr 02, 2008
Running Windows XP, 4 Gigs ram, P-4, 3.0 gigahertz. Infinity 865 PE board. Computer wiill boot up, then shut down. No blue screen or any warnings. Sometimes it will not even make it to the login screen and...
This could be a problem with your power supply.
1. If you have recently added or changed any of the components in it or have something connected to it (like through USB) that draws power right away, the power supply might not be able to handle it and will shut down. A good way to test if this is the case is to go unplug a few devices you don't need right away for the boot up (like your CD/DVD drives) and try to boot up. If it boots up just fine and stays on then thats most likely your problem!
2. It could also be that your power supply is going bad. If its old this might be the case. If you take it all the way down to the bare essentials (power supply, CPU, ram, motherboard, video card, hard drive) and it still does it, chances are you need a new power supply.
3. A few other things to consider: - check to make sure you have good air flow. If the fans are covered in dust ( specially the CPU fan and heat sink ), blow the dust out with compressed air. - Also there is a small chances that it could be your hard drive failing. If the first two options here don't get you anywhere, you might want to try a different hard drive or booting from the cd/dvd rom drive with a bootable disk. But this should be the last thing to try if nothing else works.
Again, this really sounds like a problem with the power supply, either not having enough power to run everything or going bad, so try those test first!!
Hope this helps!!
Feb 17, 2011 | DFI 865PE-ML (865PEML) Motherboard
I have e-machines T5026 with an Intel Corporation D915GAG mother board which currently has 1.5GB Dual-Channel DDR @ 133MHz (3-3-3-8). I am trying to add 1 gig of PNY RAM, #MD1024SD1-400. When I installed...
You may be using the wrong parity or out Latency ram. if they are not similar in latency they will not work in tandem. Make sure both of the ram's are the same MHZ and CS latency. Also, you may have bad ram as well. Try using the new ram first to see if the computer posts, if it does, input the old ram in the second slot, and if that doesnt work, the ram is not compatible with each other.
Feb 05, 2011 | Intel D915GAG Motherboard
Laptop shuts down on it's own
Have you checked the temperature of your system? At most of the cases like yours the reason is high temperature. In that case shut down your laptop and eject the battery. Use a soft brush (and if possible air under pressure) to clean up pedantically the air blinds all around the laptop. In case of using air under pressure leave the laptop to "rest" (and the temperatures and humidity to balance) for about 15 minutes. Check for your problem again after this.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 21, 2010 | Acer Extensa 5420-5687 Notebook
Dell 3100 suspected overheat
Try using Old RAM. If old RAM works well and new show the same behaviour, then new RAM timmings are not matching with the motherboard timmings. (
Jul 23, 2009 | Dell Dimension 3100 PC Desktop
Adding ram, but computer freaks out.
there is a jummper on the mother board you need to take off.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Emachine 5026 memory
So then are you trying to put in two more 512s for a total of 2 gig or are you putting in two 1 gigs for a total of 3 gigs? One other thing to make sure of: all the ram should be the same type (SDRAM, DRAM, DDR SDRAM, etc and have the same speed (800 mhz, etc). check this and if they do not match, that may be your problem. Let me know what the size of each individual stick of ram that you are putting in.
Nov 08, 2008 | Computers & Internet
GA-8IPE1000 Pro
Hi, Does it start to boot from windows and then shut off or is it before windows? Try removing the HDD and see if it will still shut down. If it does not shut then with the HDD removed, then the OS on the HDD is corrupted. Thanks, Mike
Nov 02, 2008 | Intel Motherboard
You have the answer in your question. I have checked the PC specification and you are right, it uses PC2700 memory. Therefore you need to install PC2700 memory. PC3200 memory will be the wrong speed and will not be supported.
Apr 18, 2008 | Computers & Internet
Mercury KVM800M Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
