Question about Countryman ISOMAX E6i (E6IOW5BC2) Microphone
A little more info on our poblem
Our countryman is brand new. has been popping since day one. could it be a problem with positioning of the tip relative to the pastors mouth. it sounds the same as when you tap the tip of a lapel mic.
Sorry to say - but that's really poor advise to suggest placing a capacitor on your brand new mic!!! Don't do it. That will immediately void your warranty. Instead, take your Countryman back immediately to your dealer and trade it in for a Audio-Technica BP892cW-TH. Believe me, the Countryman E6i's are nothing but cheap headaches waiting to happen - then when you try getting them serviced from Countryman Associates, you'll learn first-hand what a real nightmare and expen$ive headache is all about. The Countryman E6i's are both highly over-rated and highly over-priced. Do yourself a favor and get rid of the Countryman while you can. The Audio-Technica is the better solution. You won't be sorry. Good luck.
Posted on Feb 03, 2012
  • 3 Answers
The problem may be resolved by placing a 330 PF capacitor across the mic's two input lines. With countryman you cannot access the mic capsule easliy so it is best to take the TA5F connector apart,( this would be the connector that plugs into the beltpack) and place the capacitor across the two lines. LECTROSONICS.COM has the capacitors and a wiring diagram to help solve this. The part number for the capacitor is SCC330P
Good Luck!
Dale Robertson
Posted on Feb 02, 2009
Bought a brand new mini countryman 2014 from bmw Bruma later bumped it slightly but to my surprise all the air bags deployed.Have tried solving this problem with them they even took it as far as German...
Sorry, but we are no legal firm, we don't do claims, we don't have reports. Here you only find volunteers who try to help people, by answering (most technical) questions. We don't sell phones, we don't throttle data bundles we don't obstruct phones, we don't send mails. We don't call people, nothing of that at all..
Please try to contact the site that can help you on this. We are not Google nor the only solution for things that went wrong.
Jul 17, 2014 | 2014 Mini Cooper Countryman
How do I make the rear set as in my countryman lie flat?
It doesn't that is a problem we have. Maybe they will fix that in their new models.
Sep 28, 2011 | 2011 Mini Countryman
Is a little bit noisy while sewing
your description is brief so not sure if this is an old machine, new machine, never been serviced, or what brand and model.
But all machines need to be cleaned (bobbin hook area) with a little brush to remove lint and built up. And oiling the designated points as per your sewing machine manual.
And the needle should be changed for each new project, a needle is good for 4-6 sewing hours, after that it will blunten. If you stitch slowly and can hear squeaking or popping noices, needle is blunt.
For general maintenance tips if you don't have a manual yet, try www.sewing.about.com, its got lots of info.
Mar 07, 2011 | Sewing Machines
Volume goes out after slight "pop" noise
Yea you should get a sony full HD because that is the best brand
Sep 02, 2009 | Insignia NS-LCD19 19 in. LCD TV
Brand New Rebel Pocket Watch How to Set
The pushbutton in the center of the winding crown is for watch case opening only. When you push it, the front lid should pop up, revealing the dial.
If you want to set the time, you have to pull out the winding crown (not the pushbutton) and adjust the hands to desired time. After setting the time push the crown back in and the watch is back in winding position.
Rate me, please.
Mar 23, 2009 | Watches
I have no sound from my E6
Check the headset closely around the mic capsule and ear attachment for placing the mic on your ear. This is prone to problems from bending the mic to fit different people. You may find a break in the metal under clear rubber material. Also the cable itself could have a problem. Countryman sells the cable and it unplugs rather easily. There is a junction in the cable that is actually a plug. You can pull it apart there. Be careful as the mic is very expensive. Also countryman provides excellent technical support. Good luck.
Drobertson
Dec 28, 2008 | Countryman ISOMAX E6i (E6IOW5BC2)...
Popping over the house speakers.
Has it always done this or recently started?
Try to determine if the popping is coming from the words spoken into it, or if you get popping from simply moving the mic and cable around. if you get popping from simple movement, there is a chance that the mic needs to be replaced. We use these in our church, and over the last 6 years I've had to replace about 6 of them...sometimes they go bad in the wire, sometimes inside of the mic. The wires are so thin, excessive use wears them out sometimes. Depending on the model countryman that you are using...I've seen them become disconnected where the mic. meets the wire...some can disconnect here beneath a rubber coupling...if you have this model, make sure that it is properly seated.
If there are no shorts in the mic or cable, and you only hear the popping while speaking into it, you may need to filter out the low end on this channel only (everything below about 120hz - 180hz)...and try using a wind shield to help control this.
Hard to troubleshoot without being there, but I hope this gives you a few good ideas.
Mar 30, 2008 | Countryman ISOMAX E6i (E6IOW5BC2)...
Countryman ISOMAX E6i (E6IOW5BC2) Microphone Logo
221 people viewed this question
Top Countryman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Countryman Audio Player and Recorder Expert? Answer questions, earn points and help others
