Question about Sony Playstation 3 (PS3) Console
WRONG DISPLAY SETTING
I WAS MESSING WITH MY DISPLAY SETTINGS AND CHANGED IT TO 1080P. NOW I CANT SEE THE MENU TO RESET IT. HOLDING THE POWER BUTTON FOR 4 SECONDS DIDNT RESET IT HELP
Hold power button down for 15 seconds, the power botton on the front.
Posted on Mar 31, 2008
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Please help MyTV won't power on!
It just blew it's power supply. There could be a fuse or reset inside but not likely. It likely needs a voltage rectifier, voltage regulator, or a diode or a resistor, perhaps an IC. Find a factory authorized technician (they have schematics and oscilloscopes)
Oct 21, 2013 | Mitsubishi WS-65819 TV
Won't play 1080p discs?
From this problem's description I have to assume that either the blu ray player will not play blu rays or the blu ray player will play blu rays but only in 1080i/720p or that you want to know if this blu ray player supports the 1080p resolution.
If the blu ray player is not playing blu rays then you update the firmware and try multiple purchased discs to make sure nothing is wrong with the ones you have been trying. If blu rays that played once will no longer play, then you will need to reset the blu ray player from its menu and possibly by holding down the power button on the front of the unit until the word reset displays on the unit before trying to play the disc again.
If the television is not showing 1080p make sure you are connected with an hdmi cable and that it is the right version hdmi cable for this blu ray player and for your television. Make sure you have chosen 1080p as the resolution to display in the blu ray player's menu. If all of that has been done and 1080p will still not display then it is a case of incompatibility between manufacturers--Sharp and whatever the television is. It would display in 1080p on a Sharp television and most likely on a Samsung and Sony as well. With other brands and even some models of the aforementioned brands (except for Sharp) its a toss up.
Mar 05, 2011 | Sharp Aquos BDHP50 Blu-Ray Player
I've had my Sharp Aquos LC20E1U for a number of years. A couple of times recently it just shut off on its own. It started OK again the following day. However, last time this happened, it wouldn't even...
service menu procedure text changed by midge to work with Sharp LC-32P70E & probably the same for similar models.
There are probably ways of really messing up your set if you do the wrong thing from the service menus, so do this at your own risk:
To enter service menu, make sure the set is plugged in but turned off at the power button on the top of the tv,
then while holding both input button and volume down button, push the power button. Within about 5 seconds, the set will power up keep holding the input and volume down buttons until a small "K" appears in a box on the left side of the screen. Then press and hold the channel down and vol down buttons at the same time to enter the service menu.
Once the service menu is displayed on the screen, you can get the screen to display different levels of solid grey by pressing the number keys on your remote. i.e. press "1" to get a relatively dark grey, 2 for a lighter grey, and so on up to 6 which is a bright white screen; 7, 8, and 9 don't appear to do anything. (this was for adjusting grey levels, other settings are available too) Press any number a second time to return to the service menu...
Not sure wether the grey background settings apply, but for entering the service menu it does.
I think to get out of service mode you have to disconnect the TV from the mains and wait about 30 seconds.
it's some time since I used the service menu on the Sharp Aquos but I do remember you can do a full reset to factory settings as well as turn on, off and reset certain system settings too you will just have to experiment with the remote keys, I think the colour fastext key access different menu levels etc but as I said I am unsure, at least this procedure will get you there so you can try for yourself.
Hope this helps
Please come back to let me know if the service menu procedure works for you.
Good Luck
Midge.
Feb 10, 2011 | Televison & Video
So i was messing with the display resolution, it was working fine before i started messing with it... i changed the resolution from 1080i with component cables... to 1080p. I lost the picture unti i...
1080i only works with component cables and wont go to 1080p but your hdmi will set it back to 1080i and then switch back to the component cables.
Jan 03, 2011 | Microsoft Xbox 360 Console
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
"Invalid format" PS3 / LG
Try holding down the on/off button until it beeps once. this should reset the display to the original setting.
Hope this Helps
-Cody
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
