Question about XFX NVIDIA GeForce 8600 Graphics Card
My graphics card is xfx 8600 gts my card problem is when i start my pc the display logo of my m/b is crash color and red boxes on the screen then my pc restart when system reach windows. So please help me
    Novelist:
    Scholar:
  • 103 Answers
Its a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
Posted on Jun 05, 2010
Bfg 8600 GTS OC
While BFG used to have a good warranty, they went out of business in late 2010, which makes a replacement under warranty very unlikely.
If you have another PC you can install and test it in, I would try that. But it does rather sound like a graphics card problem to me. Which means a replacement will most likely be needed.
Luckily, you can get a very decent, if not better, card to replace it for less than $100. I would recommend anything in the Fermi graphics card,either 400 GTS or higher, which I have (with or without rebates) in the $100 range. PNY, Gigabyte, or XFX are all brands I have used, they have at least 3 years warranty on them.
Jan 21, 2012 | BFG Technologies GeForce 8600 GTS OC 256MB...
I need nvidia geforce 8600 gts 256 mb installation cd software and i have windows 7 62 bit. version
No you dont, you just need to go to nvidia.com and download the latest drivers.
You should also check for new drivers every few weeks if you play many games.
You also dont have a 62 bit version of windows, its 32 bit of 64 bit.
You can find your drivers here if you have the 64 bit version of windows http://www.nvidia.com/object/win7-winvista-64bit-258.96-whql-driver.html
Sep 05, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
Hi I use the Gforce 8600 gts and when ever i try to talk on ventrillio i get all these blocks all over my screen then it turns into a million little ones till i can not see anything i have to resatrt my...
Its a GPU problem.
When rendering high image resolution, this normally
happens on all application, which are VideoRam hunger.
4. Remove the pin.
5. Switch on ur PC.
9. Switch it off.
11. Power on ur PC.
thats all.
Clarifications:
May 08, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
My graphics card is xfx 8600 gts my card problem is when i start my pc the display logo of my m/b is crash color and red boxes on the screen then my pc restart when system reach windows. so please help me
well my experiance with that card having a similar issue. i tried switch cables resetting the monitor to factory settings reinstalled drivers removed the card reinserted it. called xfx and it ended up being bad they rma it and got my new one and it worked fine then. hope this helps
Mar 24, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
I got my new XFX NVIDIA GeForce 8600 GTS 512MB yesterday for my dell dimesion 9200 but when i was connecting it to the power supply the instructions say u have to "connect two molex connectors from the...
You can but a molex splitter so that you can plug the single molex you have into it and then have two, like a "Y". You will probably have to go online to a company like www.tigerdirect.com, www.newegg.com, or www.circuitcity.com who sell power supplys. I realize that means waiting a few days but the alternative is to either modify your PSU which voids the warranty or buy a different one. The splitter is inexpensive.
Nov 10, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Dualview display disappeared
just disconnect tv connection and plugin the monitor connector the display should come automatically.
then go to nvidia control panel and connect tv and then configure the dual display.
then both will again work again.
Apr 18, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Screen not starting after installing graphics card
Hi rohit1987,
The XFX NVIDIA GeForce 8600 GT 256MB DDR3 PCI Express card uses two DVI ports on the back of the card. Display is most likely coming from the second port. Try moving your monitor cable to the next DVI port. You can do this while your system is running.
If you still do not receive display, post that here & we'll go over some other possibilities.
Good luck rohit1987!
Thank you for using fixya.
Mike
Jan 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Breaking display
try to uninstall the nvidia driver in the control panel and then reinstall the drivers from Nvidias website.
Oct 01, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
"Device will not start"
Does your mobo has a built-in graphics card? try disabling that onnthe bios.
May 13, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
Sli
Hey, set the bios setting to auto. As far as I know and I have two 8600 GTs in my pc on sli I havent had to do such thing in the control panel. Directx diag reports 1008MB of videomemory for me. (both cards)
Havent had any problems myself Il test that when I get home tonight. Il provide you with more help incase I have to sort the same problem in my own pc.
Feb 15, 2008 | ASUS A8N-SLI Deluxe Motherboard
XFX NVIDIA GeForce 8600 Graphics Card Logo
344 people viewed this question
Top XFX Computers & Internet Experts
David
David
KG John Justin
KG John Justin
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
