Question about Technics SL-1200MK2 Turntable
I have sl-1200mk2, and the signal does not come in
I have sl-1200mk2 and the signal does not come in as strongly through the red rca cable. I popped it open and the red rca contact point does look a bit let like one big secure blob. What should i do?
  • Technics Master
  • 5,391 Answers
The first thing to is try to eliminate the cartridge as a cause of the fault. You can do this by swapping the connections around on the cartridge. If you get the weakness still on the Red cable you know it is that. Solder joints do cause trouble, often the earth is the problem. Try resoldering the joints. Or replace the entire cable as there might be a break.
Posted on May 16, 2010
2 Suggested Answers
  • 135 Answers
SOURCE: i have sl-1200mk2, and the signal does not come in
The phono cable's do tend to fail, usually near the phono plug or under the cord clamp.
The best option is to replace the cable - look here :-
http://stores.ebay.co.uk/methleykev
Posted on Jul 19, 2010
I need my rca's changed cause of break in the wire. Can I do this myself or Do I need to have a repair shop do it? On my SL 1200 MK2
you could try cutting off the cables leaving enough to strip them back a bit, buy some rca leads and using electrical screw connectors ( the type electricians use and also find inside light fittings to wire them to the mains) and connect it like that? failing that get it done at a hi fi repair shop? good luck
Sep 28, 2009 | Technics SL-1200MK2 Turntable
Sl 1200 mk2 no sound comming out new needle
It sounds like the rca (phono) leads also check your cartridge.
Regards.
http://www.audiovisualservices.info/
Dec 16, 2008 | Technics SL-1200MK2 Turntable
Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 14, 2008 | Technics SL-1200MK2 Turntable
Phono Preamp buzz
Don't forget to ground the ground cable from the turntable.
Sep 15, 2008 | Technics SL-1200MK2 Turntable
** sound
First and foremost, make sure you plug into directly to the PHONO input of your receiver. If your unit does not have a PHONO input, then you wont be able to hear much coming from the unit. The PHONO input is a pre-amplified input, and this turntable requires an amplified input in order to transmit it's signal correctly. Just using an AUX or LINE IN will not have enough power to increase the signal of the turntable. You have the option of purchasing a PHONO PRE-AMPLIFIER (range in price from US$15-30), or purchasing a new receiver with a PHONO INPUT!
If you have it connected to your phono input, and still no sound, your turntable may have either faulty RCA cables (red/white cables), or a bad tonearm - in either case will need to be replaced.
Hope this helps.
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 09, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
165 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
