In asus P5VDCMX motherboard power led and ide led doesnot glow but pressing power switch cpu fan runmonitor screen blank.
  • 721 Answers
Ok,here's a basic troubleshooting list. First,if it has an onboard video port,switch to it or to an agp card,whichever isn't the current hook up. Try a different monitor too when doing this. This is to see if it's a video issue. Next, take one ram stick out at a time & keep trying to boot, if it eventually does,the stick you just removed is bad. If you spliced any fans or lights in, make sure they aren't grounding on the case. If you just put this board in,the case is probably grounding the board.Remove the board & make sure the standoffs are in the right spots(lined up with the holes on the board),adjust as neccesary & then re-install,try again. Being that there's no lights, I think that grounding scenario is going to be the issue. Lastly,try a different power supply,if that doesn't work the board is bad,hopefully the cpu survived.
Posted on May 17, 2010
P5p800vm no power
Your PSU would seem to have failed.
Aug 15, 2013 | PC Chips Computers & Internet
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Pc not starting from pressing power on. Green LED for SB_PWR is on and when power switch pressed, fan & cool fan flicker momentarily but nothing happens. They do not spin. No LED light appears on front...
> PC had been suddenly powering off several times intermittently for a few days leading up to this state. Does this mean the PSU or Motherboard is at fault?
Yes, either CPU or PSU or motherboard are the likeliest culprits.
It's easier to try a different PSU than to try a different CPU or motherboard.
Nov 18, 2010 | ASUS K8N-E Motherboard
In asus P5VDCMX motherboard power led and ide led doesnot glow , but pressing power switch cpu fan run,monitor screen blank.
mybe something wrong with your hardisk or Motherboards.you can sheck with manually open the case and try to reconect and conect again the cable.
Mar 24, 2010 | ASUS Computers & Internet
I had cleaned my precision 530 workstation. After cleaning, the compuate doesnot load the BIOS. Even the fans are not getting switched on. But the light on the motherboard glows In the front panle the LED...
please make certain your memory chips are seated into the mainboard. Also, make sure that your mainboards power cable, and your CPU's power cable (the small yellow and black one) are secured to the board. If your components are secured to the board correctly, you may have an issue with the board, CPU, or power supply. If your pc is under warranty, I suggest you contact Dell for troubleshooting.
Oct 26, 2009 | Dell Precision 530 XEON Workstation Dual...
Asus M2N / Antec SP-350
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Sep 10, 2009 | ASUS Computers & Internet
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=99&name=Cooling-Products
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Mike
Apr 18, 2008 | Intel Motherboard
Where do wires go?
there is a pin-out for the front panel interface in the user manual, There are pins for Power button, reset, HDD activity, and for a few other functions THIS IS NOT WHERE THE FANS PLUG IN. The fans connect to the Fan connectors, there are usually 2/3 on the board, 1 near the CPU, 1 near the memory and 1 usually close to the IDE/ SATA connectors
Oct 07, 2007 | ASUS P5VD2-MX SE Motherboard
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
