Question about Mitsubishi WS48511 48" Rear Projection Television
Need replacement screen for Mits. WS-48511
Does anyone know a source for parts to a Mitsubishi rear projection TV Model:WS-48511. I realize it is old, but it is a decent TV in a second home. I need to replace the front plastic screen. The TV works great, just someone decided to punch a hole in the front.
  • gilvogel Mar 31, 2008
    Thanks for the insight. Can you point me to the site? Would I be able to rely on product description measurements? I do not have access to the physical TV again for another month since it is at a second home.
  • Mitsubishi Master
  • 8,617 Answers
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Posted on Mar 31, 2008
  • Sonny Berry
    Sonny Berry Mar 31, 2008
    If the product discription has the screen dimensions that would work perfectly. As they have the equipment to resize the larger screens down to fit any mitsubishi. I posted the link in my other post but here it is again.
    http://servicemanuals.vstore.ca/
My TV is a Model WS-48511. The picture is very
The dm board is the most likely cadidate judging from your description.Sometimes they can be repaired by replacing faulty surface mount capacitors on the dm board.The board itself is probably not available anymore.
Dec 01, 2009 | Mitsubishi WS48511 48" Rear Projection...
Tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
on May 03, 2010 | Televison & Video
Tip
Download Mitsubishi WS-48511 HDTV Manual
Have you misplaced your Mitsubishi WS-48511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-48511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Replacement Parts - Rear Projection TV Mits. WS-48511
possibly . here is the link I am one of the support techs there and we have alot of the 50 inch mitsubishi and we resize the screen assemblies to fit various mitsubishi models . Heres the link.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Replacement Parts - Rear Proejction TV Mits. WS-48511
Visit http://www.vstore.ca for used lenticular and fresnals. They will size to fit.
Mar 31, 2008 | Televison & Video
Tip
I hope that helps.
Tip
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-B55 Manual Download
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-48511: can't adjust blue convergence
Replace R8c21 & R8c22 (3.9 Ohm 1 Watt) Ic8c00 Stk393-110 Mits. Part # 267p155010 (Use Sanyo Original)
Also Check F9a04 (5amp Pico Fuse) for open and replace if necessary.
Bill
Dec 21, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi WS48511 48" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
