Question about Dryers
I have a Maytag MD55 dryter and one of the paddles
I have a Maytag MD55 dryer and one of the paddles inside the dryer is coming loose how do I fix it??
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
Posted on Nov 03, 2010
Why is my Maytag Neptune Elec Dryer MD55 chirping? How can I fix it?
Could be a bad spot on the drive belt. Each time it moves over the motor pulley it slips. If the chirp is happening at the same interval over and over I would check the belt.
Mar 28, 2015 | Maytag Dryers
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
The blade inside my Maytag Atlantis dryer is loose. How do I fix it?
if it has the sloped front and door at the top front,then open door and remove 4 screws 2 on each side remove door then there are 2 screws under front of top cover remove these, then pull outward on door from edged of front cover to remove, then lift up top cover,then you can tighten or remove and replace paddles
Mar 11, 2012 | Maytag Dryers
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
One of the paddles inside the drum has come loose on one end--broken fastener. How do I take the top off to fix it?
you have to start by taking off the door at the hinges, then the front panel will twist off at the smaller raised portion, about 2 inches wide. once you have the front off, you will see the screws that hold the top to the front.
the drum baffles are held in with screws and if you can just use a bigger screw or just tighten the ones that are there.
Mar 13, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The paddle came off inside my Neptune Dryer
The screws for the paddle can be accessed by removing the small back panel. If they are stripped out you will need a new paddle.
Jun 07, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
