Question about Magic Chef 30 in. 8241RT Gas Cooktop
Magic chef oven: lights hard but when lit comes up to or near temp sputters and will not come back on???
    President:
  • 1,430 Answers
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 16, 2010
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
I have a magic chef oven the model number is 439w 3w, i need new burner knobs and oven thermostat knob, i need help trying to find them. Can you please help.
Hello, Thank You for using FixYa. I will be helping you today.Assuming the model is correct here you go http://lookup.bellparts.com/lookup/13830/76035
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Magic Chef 30 in. 8241RT Gas Cooktop
Oven won't come on unless you press bake and immediately hit arrow to 400 degrees. Can this be fixed
Yes, this is most likely a thermostat problem. If you have tried every temp level below 400 and it will not come on until you reach 400 on the dial, then you most likely have a temp sensor switch/ thermostat problem.
I had to assume alot of things here:
1. It is an electric oven.
2. Once you get the oven to start at the magic number and try to dial down from there, the oven turns itself off.
3. It will start up as long as the temp is first set at 400 degrees or higher.
Jan 08, 2010 | Kenmore Cooktops
One of the burners won't light. The stove top is ceramic electric. It is a Magic Chef oven. Other three burners work.
check all wires to burner and switch. If they are good .....burner burnt out or switch no good.
Aug 05, 2009 | Cooktops
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Nov 19, 2008 | Cooktops
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
-F1-
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Oct 12, 2007 | Cooktops
PILOT CLICKING
Dawnie, under each burner control there is a valve and a switch. One of your switches has either become wet or shorted out. This is why it's clicking. Sometimes grease gets in them and causes this problem. The part number for the switch is 7403p367-60. You can look it up on the net to see what Im talking about. Not a hard fix. Catriver..post back.
Sep 24, 2006 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic Chef 30 in. 8241RT Gas Cooktop Logo
97 people viewed this question
Top Magic Chef Cooktops Experts
jdthefixer
Steven Clarke
Steven Clarke
ray gallant
Are you a Magic Chef Cooktop Expert? Answer questions, earn points and help others
