Question about Brother MFC 420CN All-In-One InkJet Printer
New ink installed
The printer keeps telling me the Yellow is low and to replace it.
Says to open and replace. I haqve opened and taken it out 3 times.
Have turned it off and back on .. hoping would reset it.
Doesn't work.
Please any suggestions??
  • 832 Answers
Plz see display:
machine will ask if you have changed cart. answer with 1 (yes).
do run a firmware update!
Posted on Mar 31, 2008
I need to make the ink carriage move over so I can replace the ink cartridges inmy workforce 840. Online here it says "hit theink button" what the heck does that mean? Where is this ink button?...
this is out of the manual
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the
ink remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If you're replacing a cartridge before you see a message on the LCD screen,
press Setup, select Maintenance, then select Ink Cartridge Replacement.
3. Raise the scanner.
4. Open the cartridge cover. Then squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets
into your eyes, flush them immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package, shake
it gently four or five times. Then remove it from
the package.
6. Remove the yellow tape from the bottom of the
ink cartridge.
Caution:
Do not remove any other labels or seals, or ink will
leak. Do not touch the green chip on the front of the
cartridge. This can damage the ink cartridge.
Sep 01, 2011 | Office Equipment & Supplies
How do i change my ink cartridges in my epson workforce 520 series 3 in 1 printer?
Caution:
Leave the expended cartridge installed until you have obtained a replacement, or the ink
If a cartridge is expended, you must replace it to be able to print or copy. If a
cartridge is low, you can continue printing until a cartridge needs
replacement.
press xMenu, press u or d to select Maintenance, and press OK. Then
select Ink Cartridge Replacement and press OK.
3. Open the scanner, then open the cartridge cover.
4. Squeeze the tab on the cartridge and lift it up.
Warning:
soap and water. If ink gets into your eyes, flush them
shake it gently four or five times. Then remove
it from the package.
the ink cartridge.
Caution:
the cartridge. This can damage the ink cartridge.
7. Insert the new ink cartridge into the holder
and push it down until it clicks into place.
8. Once you replace all the cartridges that need replacing, close the cartridge
cover and push it down until it clicks into place.
9. Close the scanner.
10. Press OK to begin charging the ink. This takes
about 2 1/2 minutes. When you see a
completion message on the LCD screen, ink
charging is finished.
Caution:
Never turn off the product while ink is charging or you'll waste ink. If you see an ink
replacement message on the LCD screen, press OK and press down all the cartridges
securely. Then press OK again. If you remove a low or expended ink cartridge, you
cannot reinstall and use the cartridge.
See Page 47 in manual
Download Manual Here
May 23, 2011 | Office Equipment & Supplies
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
Yellow ink cannot be recognize by the printer
The problem is that the priter can't detect the ink, because the cartridge has low level ink. I put scotch tape and colored it yellow- on the part where the ink is detected - so the printer will detect the color I put on the tape. BUT as others said it can damage your printer if you will always do this.
Jun 24, 2009 | Brother DCP 130C All-In-One InkJet Printer
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Ink settings
Have you made sure you removed the backing plastic from the cartridge sensor?
Try reinstalling the driver and do a nozzle and head alignment test. If you still have the same issue, try doing a hard reset - unplug the printer from power and PC, wait for about 10 minutes and replug everything and see. If the issue still occurs, there could be an issue with the cartridge sensor on your printer, which will require servicing.
Sep 27, 2008 | Brother MFC 420CN All-In-One InkJet...
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Will not accept new yellow ink cartridge.
Do you use generic carts?
If yes try another cart (always best: original brother carts)
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=mfc210c_all&Cat=11
Dec 23, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
