MY UNIT SEEMS TO RUN ALL THE TIME, NEVER CYCLES
My unit seems to run all the time never cycles on/off when the heater or ac is on. Have turned on and off cleaned filter.
  • 53 Answers
Make sure its on auto,,an if it is then you probally need an t-stat
Posted on May 16, 2010
On a Friedrich in wall AC/Heater in the heat mode in the digital display while the unit is working fine I get a flashing 08 alternating with the temp of 74. Model # PDE15K5SB-A is this a trouble code
This is an error code for "Unit cycles more than 9 times per hour". The service manual says the possible causes are "Unit oversized" and "Low load conditions".
Jan 10, 2015 | Friedrich Heating & Cooling
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
Aug 13, 2011 | Dishwashers
The refrigerator make a clonking noise intermittently, It seem to be at the end of a compressor cycle. I am not sure of the time between the cycles, but I started noticing the noise recently and it seems...
this must be a older unit . and what you can hear is the compresor comming to rest . the clonking noise is the mounts inside the seald unit . have or are failiing . due to age . best solution is to run it till it won't . it may take years before it won't go . hope this hepled mm .
Oct 16, 2010 | Refrigerators
MY UNIT SEEMS TO RUN ALL THE TIME, NEVER CYCLES ON/OFF, WHEN THE HEATER OR AC IS ON. HAVE TURNED ON AND OFF, CLEANED FILTER.
Need to have charge checked. You can check temperature difference yourself. Turn to coo. Take a reading of air going in and coming out. It should be between 18 to 22 degrees. Anything less you are low on refrigerant. Russ
Mar 24, 2010 | Heating & Cooling
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Smelling fumes from 4xl55. Also cycles many times b4 igniting.
Hi jim if you are smelling fumes turn it off and get a service done on it asap
Mar 27, 2009 | Dayton Gas Furnace Heater
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
FRIDGE AND FREEZER WON'T COOL. OVEN DIRECTLY IN FRONT OF FRIDGE IS TURNED ON AND LEFT OPEN TO WARM HOUSE SOMETIMES(HOUSE HEATER BROKEN TOO). COULD THE HOT AIR HAVE DONE SOMETHING TO FRIDGE?
The oven is more likely just a coincidence. All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. The Defrost timer in all boxes fails eventually from old age. When that happens, the coils frost over until they become pretty much just a solid block of ice. Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is running, give the shaft a slow twist until a click is heard. The compressor will stop. Give the fridge an hour to defrost the coils, and check it to see if it took off running. Sometimes the nudge will make the timer run for a while. If this is the case, the unit will chill, and buy you some time to get it fixed. If the timer does not run, you can repeat the process daily until you get a replacement timer. If the unit does not chill, there is some other problem either with the defrost heater coils, or the sealed system. If this seems to be the case, make sure the condenser coils under the unit are not obscured with accumulated dust/dirt and that they have airflow from the fan behind them. For heater or sealed system repairs, you should call a servicer.
Dec 17, 2008 | Refrigerators
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
