Question about Nikon Super Coolscan 5000 ED Film Scanner
Can not remove film tray from scanner . Film tray is stuck
I have turned off the power and then used a wire hook manufactured out of a coat hanger to pull it out. My problem is not with it getting caught but with trouble locking the film in place. Any problem or solution for that?
Posted on May 27, 2010
Nikon coolscan 5000ed, film stuck, will not eject
If you switch off the scanner you should then be able to remove the grey film holder, even though the film strip will still be inside. Then, press the small button above the film entry slit to open the front of the holder. Pull up the top cover, ease the bright metal holder strip forward then lift the metal flap that holds down the film strip. At this point you should be able to remove the film strip. Re=assemble and try again.
Good luck.
May 18, 2014 | Nikon CoolScan V ED Film Scanner
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
How do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Jul 07, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scanner not working
hrm, i found out how to solve the issue. remove the film and do a calibration for the frame, now the scanner starts to calibrate, after a 30sec the program told me to put the film in and scan.
tadaaaaa..
Jan 13, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
KM DiMage Scan Elite 5400 II
I have same problem..Are you find answer!? Thanx!
Graksi
Dec 03, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
Coolscan ed 4000
The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
Aug 15, 2007 | Nikon Super Coolscan 4000 ED Film Scanner...
Open Questions:
See all Nikon Super Coolscan 5000 ED Film Scanner Questions
Nikon Super Coolscan 5000 ED Film Scanner Logo
174 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
