Question about Cross Infoguard Shredder SX102M
SX-102M Shredder Our SX-102M shredder has a damaged head assembly, which appears to need replacement. Is there a source where we can purchase the head assembly for this shredder? Thank you. J&E Fraser Morgan Hill, CA
  • jim126 Apr 01, 2008
    Ramah..
    Thanks for your kind reply.
    Indeed, the head assembly is damaged. Today, I plan to open the unit up, to see if I can do any useful repairs. In either case, I will let you know what develops.
    Thanks again.
    Jim
The "Head Assembly" IS the shredder. If that part is bad you have DEEEEP trouble. I can tell you though that the primary exchange gear is likely stripped. It is nylon and can't take much abuse. How do I know??? ... 'Cause I have one just like it!!! Let's trade. Maybe we can get one good one out of the two. In the future (as I have carefully explained too my daughter!!!) don't put more than 10 sheets in at a time!!!
By the way... the only part left after the "head assembly" is a waste basket..
Ramah G. Martin (the guy who fixes things)
Glenn@ramahg.com
Posted on Mar 31, 2008
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Infoguard shredder SX-102 runs in reverse but not forward
Shredders have a manual switch for reverse..... if you have tried this, then there could be a possibility that the switch has dust of paper in it and the contacts not making contact for the reverse cycle... or the switch is faulty. If you have any electrical knowledge, you can do a test with an ohm meter for continuity in the reverse mode.... or remove the switch and blow it out with an air compressor. If you mess with electrical, ALWAYS REMEMBER TO UNPLUG THE SHREDDER!!!
Good luck.........
Jul 14, 2014 | Achiever CCS5000 Shredder
Can the head(cutting assembly) be replaced? purchased?
Contact ROYAL at 1-800-524-0799 regarding replacement parts and pricing.
Jun 08, 2011 | Royal RL170MX Shredder
Broken cog spool - replacement
Hi you should buy new shredder because you will not get the plastic part easily and usually they do not be replace.
Jul 28, 2010 | Fellowes P57Cs Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
Sx 102m reverse works, and auto does not work
Did you try blowing out the sensor with canned air?
No spare parts are available.
Jun 21, 2009 | Cross Infoguard Shredder SX102M
Need a replacement parts
Try calling their customer service in the US at 800-945-4545.
Feb 01, 2009 | Fellowes DM8C Cross-Cut Shredder
Large Metal Gear Wanted
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Sep 14, 2008 | Cross Infoguard Shredder SX102M
Sx-102M
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Dec 21, 2007 | Cross Infoguard Shredder SX102M
Plastic drive gear from motor broken
I have a left over set of these plastic gears that I can send to you. The motor bracket on mine snapped. I took it apart to check. It looks unrepairable.
edbwest@aol.com
Oct 31, 2007 | Cross Infoguard Shredder SX102M
Cross Infoguard Shredder SX102M Logo
174 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
gbob59
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
