Troy bilt pressure washer 2200 psi
Troy bilt pressure washer will not draw in soap through the tube for washing solution.
  • 3 more comments
  • ptrjrv May 23, 2008
    will not draw soap
  • Anonymous Jul 19, 2008
    I have the same problem and have tried the black nozzle, it didn't work still.
  • jlfdadx3 Aug 22, 2008
    will not draw soap or supply ample pressure
  • Anonymous Nov 13, 2008
    I have a troybuilt 3000 psi unit and have the same problem. since it was new the chemical would not pick up.
  • Anonymous May 02, 2009
    I have no manual , do I mix oil and gas or are they seperate
Inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Posted on Apr 08, 2009
I'm using the low pressure nozzel and it still will not draw the soap.
Posted on Mar 22, 2009
Are you using the correct tip? The soap injector will not work with the high pressure tip installed. The soap tip is sometimes color coded black.
Posted on Jun 30, 2008
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt pressure washer not siphoning soap
clean and soak all valves if do get work do not leave solution in it over time.carb cleaner with that little straw
Oct 19, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Need instructions on the use of the soap dispenser on a 2700 psi B&S power sprayer
Dear Audience,
Please go to the link provided and view the on line PDF manual. On pages 16 and 17 you will find the directive to apply detergent into the system and maintaining successfully.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/020292%20man.pdf .
If you are having any difficulty , please check out this direct source Troy bilt Pressure Washer Support ManualsOnline com .
Fare. Well.
Sep 24, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Jun 08, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
I have a 2200 Troy Pressure washer, I cannot get it to draw a detergent solution. I am using the black soap nozzel, i have a new siphon hose. any ideas?
Dismount the bolt that is use to connect the soap line.Turn on the washer and test if you fill if is "suction" intake air.Sometimes it becomes clogged so see if anything is clogging the suction .Is that not work the suction system is bad.
Nov 13, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Washing Machines Logo
2,613 people viewed this question
Top Washing Machines Experts
