Question about Navy Seal Luminox Watch
Stopwatch Watch stopwatch feature will not reset to 12:00
  • PSU David Mar 31, 2008
    Can't get back off without sending away
    With crown out all the way, pushers does not move any of the movements.
    Genius:
  • 1,226 Answers
Try removing the battery and to reset all the setting.
Posted on Mar 31, 2008
  • Emelio Navaja
    Emelio Navaja Mar 31, 2008
    refer to your manual for hard reset setting or reset to factory setting. melnavz
  • Emelio Navaja
    Emelio Navaja Apr 01, 2008
    maybe reset pin not function, you need to disassemble it maybe to realign all the parts in it.
  • 3,037 Answers
You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
  • Benjamin Patri
    Benjamin Patri Mar 31, 2008
    let me know if this isn't what you wanted or didn't work
  • Benjamin Patri
    Benjamin Patri Apr 01, 2008
    there should be a spot to pry off the backing
How do you set the watch to use stopwatch feature
No need to set the watch - if it has stopwatch feature, you just have to push a pusher and counting will start.
Aug 28, 2014 | Watches
Wont stop beeping
OMG me too!! Just got the watch today and none of the features to stop/start or reset respond!!! It's crazy...
Feb 06, 2014 | Nixon The Genie Watch
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
I have a 1970 locman stainless steel chronograph. when i use the stop watch feature. the second hand does not return to the 12 o'clock position. instead it lands on the 3 o'clock mark. how do i re-set...
I don't know if this is the same for you, but on my watch I can pull the winder all the way out for the time setting and then I hit the start button for the chronograph and it will adjust the second hand. Hope this helps.
Thanks,
Eric Pederson
GVDCOPS
Jan 13, 2009 | Locman 1970 - Black Stainless Steel...
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Rolex Daytona Chromograph
ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
Apr 26, 2008 | Rolex Daytona 116520 Wrist Watch
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Navy Seal Luminox Watch Logo
235 people viewed this question
Top Navy Seal Watches Experts
Jax Planet
Jax Planet
deton8 von Splosion
Jim Weinandt
Jim Weinandt
Level 1 Expert
Are you a Navy Seal Watch Expert? Answer questions, earn points and help others
