C warning problem
The letter C, in caps "C" appears in the lower right side of the screen on my HP15C handheld calculator [10 series]The sin,cos,&tan functions are not giving correct answers and I just changed the battrys; I do not have an owners manual; how do I rid myself of this mode or what/why is it doing this? I loaned it to a friend to do calc's during class, he has no clue what he did...I donot know how to reset...or if that helps this problem?? please help; 3/30/08
pocoranch@sbcglobal.net
  • 37 Answers
Try removing all batteries and waiting for 5 mins then reinsert.
Posted on Mar 31, 2008
Can't add files
The device should appear on the lower left part of the explorer window.
See screen capture below.
May 07, 2013 | Texas Instruments TI-Nspire Graphic...
Tip
Factory Reset for Palm z22 handhelds
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. Under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
4.On your handheld, hold down the Power button.
5.While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
6.While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
on Mar 11, 2010 | Cell Phones
Tip
Factory Reset for Palm TX handhelds
6.While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
My notebook keyboard automatically converts some keys into calculator mode, i want to reset it into letters mode
On your laptop look in the lower left corner for a key labeled with the letters "fn", in blue letters.
Look on the upper row of keys near the right side for a key with "num lk", "num lock" or an icon that appears to show a calculator.
Hold down the fn key while you press the other key, when you release both keys this mode will be turned off and the key will again function normally.
May 17, 2011 | Samsung N150 Notebook
Need instructions on a hard reset
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
Malfunctioning keyboard. If touch a letter A a different letter will come up. same thing trying to use the calculater.
the screen needs calibration. below are the instruction on how to calibrate the screen. The Digitizer Preferences screen opens the digitizer calibration screen. This is the same screen that appears when you start your handheld for the first time. You can recalibrate your screen after a hard reset or if your digitizer drifts. You may need to repeat this process a few times until the calibration registers. To calibrate your handheld screen: 1. From the General Preferences list, select Digitizer. 2. Tap the targets as indicated on the screen as precisely as possible.
TIP You can also press Left, Right, Up, and Down on the navigator to highlight a Preferences screen name and then press Select on the navigator to open that Preferences screen.
Aug 04, 2010 | Palm Zire 71 Handheld
I don't know how to multiply by a negative exponent. ex: 10(-8) ....the -8 is the exponent.
Press [2nd][,] to activate (EE) which appears on screen as a lower case E, enter the change sign (-) right of the [dot] on the bottom row of keys, enter the value of the exponent.
Ex: Enter Avogadro's number of Generalk Chemistry fame
6.02[SHIFT][,] (EE) (-)23
Here is screen capture of what it will look like.
Feb 23, 2010 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
