Question about Home
Toilet continuously runs - Home
  • 349 Answers
Check level in tank to make sure water is not running down over flow pipe. The float in tank should be cutting water level off about 5/8 inch before top of pipe. If this is it adjust the float or valve for proper level it shoul dhave amark on stand pipe also..
Also check flapper and make sure it is sealing off after you flush it can get caught on chain or what ever is connected to it from handle. If it is too long you can adjust it also.
Posted on May 17, 2010
pranaclimbin
  • 50 Answers
SOURCE: my toto toilet keeps running
if its a metal arm connecting the ballcock shut off valve to the float flush it and bend the metal so the float is lower. if u can adjust the ball **** lower then do so. the shut off is not shutting off cause the float isnt going high enough. and the excess is going down the overflow.
Posted on Dec 04, 2008
SOURCE: Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
Posted on Aug 07, 2009
smokenic
  • 49 Answers
SOURCE: New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Posted on Sep 20, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
  • 150 Answers
SOURCE: Toto toilet is constantly running, even though the tank is full
it sounds like it might be the floater ball in the toilet you can adjust the tension on it usually with a screwdriver.... if you look from the top down you should see a screw on the top of the arm that holds the floater adjust the tension and hopefully this will work
Posted on Jan 20, 2010
1950's Eljer Murray toilet ballcock troubleshoot
Your best course of action is to replace the whole ballcock assembly with a new one. I recommend the Fluimaster 400a it is a different design but it will work well with your toilet.
Hope this helps
Bob
Jul 02, 2014 | Eljer Toilet Twopiece Murray 091017000
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
I have a american standard toilet mode 4112 that keeps running.....any suggestions on how to fix it?
The flapper ball may be contaminated and not sealing or the float level has changed and needs adjustment. You should be able to see if the overflow has water flowing into it continuously.
Mar 07, 2011 | American Standard 4112 Bone Toilet Tank...
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Nov 08, 2010 | Toto Home
Need to gt the top off of a porcher toilet we can't fogure out how to get into the tank to fix whatever continues to run
I'm not sure why this is a challenge. The lid should just lift right off unless you have a wall mount toilet. Here is a .pdf of a typical Porcher toilet and how it all goes together. There is also a handy trouble shooting guide. If the toilet is running the culprit is either a faulty flapper or fill vavle. Let me knwo if I can be of any further help.
http://www.porcher-us.com/assets/documents/porcher/install/Install_3337.pdf
Jul 31, 2010 | Home
The toilet continues to run after flushing, i.e.e
The fill valve is stuck on and needs replacement, checking this part every year is a good idea.
Mar 27, 2010 | Kohler K-3384-2 San Raphael Elongated...
I have the bellevue model and it keeps running even when the toilet has been flushed. It continuely seems to need more water and leaks a bit of water all of the time. It is a new toilet!
Your flapper is not sealing at the bottom of the tank. You can either return the toilet, replace the flapper, or try smearing a little vaseline on the underside of the flapper lip where it contacts the tank bottom. The latter may be all it needs to seal a tiny leak.
Dec 03, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Toilet continues to run. THe plastic float cup
The adjustment is inside. It just needs to be adjusted.
Jul 10, 2009 | Neptune FB1634 London XLT Toilet
Home Logo
160 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
