Question about Jensen LXA400 Car Audio Amplifier
Have Power going to the amp. Amp does not turn on. Do i need a remote? Bought vehicle with amp in it. Lxa 600 Power light does not turn on.
    Problem Solver:
  • 11 Answers
Ok remote does not mean the clicker to ur tv its the wire that leads from the back of ur deck to the amp itself to tell the amp when its cool to turn on n off either blue or blue n white is the remote wire on the back of ur sterio run it to remote term. on amp n c what happens
Posted on May 17, 2010
P1100.2 no sound
have you checked your fuses. on the amp and your amp power wire also there is a power remote wire that tells the amp to turn on when you turn on your radio.
Mar 31, 2012 | Cars & Trucks
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
I bought a Jensen LXA600 car audio amp second-hand & need an owners manual
I also have been searching for a manual for the LXA 600 Amp. Jensen's website was no help. I will let you know if I find something. Have you had any luck?
Jul 07, 2010 | Jensen LXA400 Car Audio Amplifier
Have Power going to the amp. Amp does not turn on. Do i need a remote? Bought vehicle with amp in it. LXA 600 Power light does not turn on.
you need to make sure you have 5 things.
1. power connection to the battery/amp
2. make sure you have a remote line radio/amp
3. make sure you have rca's radio/amp
4. make sure you have a ground amp/car frame ( scratch paint away for good contact)
5. make sure the speakers are connected to the radio.
if all is ok then check the inline fuse from the hot wire from the battery is not blown and the fuse on the amp is not blown.if so replace them. with the proper amp fuse.
Mar 24, 2010 | Jensen LXA400 Car Audio Amplifier
BOSS BASS 600 - No Sound .
ITS BEST TO HAVE A SOLID REMOTE WIRE WITHOUT NE SPLICES WAT SO EVER
Feb 08, 2010 | Boss AUDIO SYSTEMS BASS600 Car Audio...
The led on my lxa 600 watt amp in my dodge magnum
If the light is all that is on then it will be fine. It would take days to weeks for it to kill todays car batteries. If the amp is drawing more power than just that though, I would move the remote wire to the ignition or the headunit, because the fusebox is getting constant power to tell the amp to stay on.
Oct 10, 2009 | Car Audio & Video
Who needs a «remote DC terminal» ???
Hello labdes,
The "remote" terminal of the amp requires a +12V signal to rurn the amp on. Normally, this is supplied by a specific wire from the vehicle "head unit". But you can simply jumper it to the positive 12V source. + should go to the 12V positive and to "remote", - to the 12V negative. I'd wire a switch across the "remote" and "power" terminals to have a way to turn the amp on and off.
I'm hoping that your "car amp" has speaker level inputs, because the PC card is probably not going to have preamp outputs. If the amp has only RCA type inputs, you will need to purchase a LOC (line output converter) such as the PAC SNI-35 shown here. They are also usually available at your local car audio shop and some big box stores.
Hope this helps.
Jun 13, 2009 | Lanzar MXA 412 Car Audio Amplifier
My Amp Keeps shutting off
You need to get an amp with higher wattage. Obviously, your amp cannot handle those two 10" monsters. hehe Nice Subs though :D
May 01, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
Jensen LXA400 Car Audio Amplifier Logo
93 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
