Question about Gateway FPD1975W 19" LCD Monitor
Thin yellow line
Gateway fpd2185w monitor all of the sudden has a thin yellow line running down it. Would it be safe to say I need to change the cable in the monitor?
  • 1 more comment
  • ftna86 Sep 28, 2008
    same prob but a thin vertical pink line
  • Zngooyen Feb 01, 2009
    LMFAO i got 2 lines now one pink and one blue so freakin hard to play games -.-
  • Anonymous Feb 18, 2009
    I purchased my monitor in 2006 and recently it started showing a very thin vertical blue line on the right side of monitor. Any advice on how to get rid of it would be appreciated.
Yea if you cannot stand the line, one of the line's driver for that column has failed. I do not know if the cost of repair would be greater than a monitor. I have been trying to fix a handful of monitors here at work to keep busy, and I am finding that the manufactures won't even offer the repair boards. A google search for a power supply card for an aopen is how I found this board.
Posted on Apr 02, 2008
Have sound on westinghouse 42 in tv but no picture..just vertical thin lines..thia happened suddenly have hd box rebooted cable. tv will not turn off or on but has power
check it against another computer if the same result then its faulty
is your graphics card a standalone if so that could be the problem
but i am assuming it built in then option 1
Sep 18, 2014 | Westinghouse Tx-42f430s 42" LCD HDTV...
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
My dell inspiron 9300 has a thin yellow line running down the left side of the monitor. some weeks it will be there, sometimes it won't. help!
Reseating the video cable eliminate those lines that appear.
If your not familliar in tearing down the laptop, try bringing the computer to a local tech and have the video cable reseated. They can open the hinge cover/panel in order to access the video cable at the back portion of the laptop.
^_^
Jun 13, 2010 | Dell Inspiron 9300 PC Notebook
I have the FPD2185W. Off and on now I get small,
Check to see if there are any magnetic or electrical power supplies located recently moved near the monitor area.
Nov 13, 2009 | Gateway FPD2185W 21 in. LCD Television
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Green line from top to bottom of monitor
Try changing your resolution, if the lines stay in the exact same position (so do not change together with the resolution) this might be a mediacentre issue. Press CNTRL-ALT-DEL and see in the processes tab if ehtray.exe is running. If it is running, turn it of by unchecking it and see if the lines disappeared.
Jun 30, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Samir
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
206 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
