Question about Canon PowerShot A540 Digital Camera
Partly open lens
The Canon Power Shot A 540 has a lens that will not open all the way.  It shows a diagonal shot on the screen.  I tried changing batteries but that wasn't the problem. Today, when I tried to use the camera, the lens cover would only open a fraction of the way. I tried replacing batteries but it did not help. Suggestions? . . .
  • mmessbarger Mar 31, 2008
    The lens fully extends, but the lens cover only opens slightly. When turned back off, the lens retracts and the lens cover fully closes.
  • 3,037 Answers
The mechanical part that is trying to open the lens cover is having a problem
Possibly
1. a lodged piece of foreign material
2. A broken piece within the camera is interfering
3. A piece in the camera that helps control the lens or another piece by the lens is out of place
Please check this out if you are comfortable doing so and let me know what comes of it
Thank you
Posted on Mar 31, 2008
  • Benjamin Patri
    Benjamin Patri Mar 31, 2008
    This camera is actually know to have this problem
    You can try holding down the menu button to reset this camera and see if that works or
    you will probably have to contact canon about this and if still under warranty get it fixed for free otherwise it won't be cheap from what I always see. Most likely some gear or lever isn't getting full range of movement. If you need further help let me know but just search for reviews of this camera and you will see that this problem is very common and that it usually has to be sent in. I would probably just get a different camera and return it if I can. Good luck with whatever you decide to do.
My Canon Power Shot A95 clicks when turned on.....what do i do?
The lens is trying to extend you may need someone to repair it.
May 19, 2014 | Canon PowerShot A95 Digital Camera
Top edge of my photo is a black diagonal shadow
Sounds like it could be vignetting from either a lens hood or an accessory. Are you seeing this in all photos or flash only? If flash, sometimes a wide shot with a lens hood on will block the flash output and cause the described shadow line.
Feb 08, 2014 | Canon Eos Cameras
Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
MY CANON POWER SHOT A 80 DONT WORK
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
May 26, 2009 | Canon Cameras
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
Partly open lens
Has anyone tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
page number 114 of your manual. tell me if this works
Oct 16, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
