Question about Kenmore 23822 Top Load Washer
The water drains too fast and overflows
When the water starts to drain during the spin cycle the water overflows out the drain pipe. Is it draining too fast or is it all in the drain? It doesn't always overflow.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
Posted on May 17, 2010
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Water drains during wash cycle
A couple things to check, is it actually turning on the drain pump? Is the water valve leaking by?
Apr 10, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
I still have wet close after spin cycle Why?
check the drain hose for any kinks in it,is it a top load or a front load washer and how old is it?the pump could be blocked with something or the tranny is bad.if it's a top load,set the timer on spin cycle,open the lid,start the spin and with a screw driver push down on the lid switch and see how the machine is spinning,if it's not spinning fast the tranny is bad.if the drain hose is stuck into a drain pipe pull it out and drain the water to see if the water is draining out good or partially draining,something could be in the pump or to much detergent,the washer can't pump out suds as fast as water then the suds turn back into water form again and the clothes are wet.
Apr 02, 2011 | Kenmore Washing Machines
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Suds coming out of drain pipe.
you can buy a siphon break to connect the washer drain hose to and put down in the drain that might fix it
Apr 23, 2009 | Washing Machines
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Kenmore 23822 Top Load Washer Logo
200 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
