Question about Dell 924 All-in-One InkJet Printer
Paper won't feed
Suddenly, paper won't feed in my Dell 924 printer. Tried the cardstock solution, but the cardstock wouldn't feed either.
How would I get inside the machine to look for a paper jam? The manual is no help.
Bev
  • 1 more comment
  • Anonymous Jun 02, 2008
    my printer is not working rigth after i change the ink,the word clear the paper appears in the screen.wht would i do?
  • Anonymous Jun 04, 2008
    Paper won't feed..
  • dionv Jun 10, 2008
    paper jams as it start printing
    leaves a bend in the paper on the right side as if that side is working
All of a sudden paper won't feed on the 924 printer and I continually get a paper jam message. Can't find any jam or problem with the unit on a visible inspection. It appears there must be a problem with the feeder apparatus. Any thoughts?
Posted on Jun 19, 2008
  • 41 Answers
Dell.com will chat with you on-line to help you toubleshoot that printer.
Posted on May 28, 2008
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
Dell 924 Photo Printer will not recognize that paper is loaded
you will likely have to take this in for (hopefully free!) warranty service. it sounds like there was an assembly issue here. good luck!
Feb 17, 2009 | Dell 924 All-in-One InkJet Printer
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
924 printer
place a piece of cardstock in printer try to print on it or unplug printer and replup it in hopes of resetting it
look in paper path area and make sure no sensors are blocked
Dec 31, 2007 | Dell 924 All-in-One InkJet Printer
Dell --924 copier
clean feed in roller with rubbing alcohol on a micrfiber cloth if there is white reside on rollers you just have a traction problem
also make sure no torn paper is in the paper feed area
Dec 19, 2007 | Dell 924 All-in-One InkJet Printer
Paper feed problem.
ATN master 3202 clean paper feed rollers with a micrfiber cloth moistened with rubbing alcohol will be rollers that pull paper probably just need wiping off after a lot of use these rollers build up paper dust that causes traction problems
Nov 01, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
366 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
