Question about Reebok Rt1000 Treadmill Walking Belt
No motor output to drive the belt
Have not got any voltage at the motor (red/black) spades on the controller pcb. The led's lights flicker on both power and controller pcb's and the voltage on the control panel incoming increase's with the operation of the speed control buttons on the console. Have also checked the motor with a 12v battery and it operates fine. The thermal sensor is closed and reed switch is clear. Any ideas????
    President:
  • Reebok Master
  • 832 Answers
If speed ctrl LED is flickering and no DC output on motor spade then the motor control board is defective and needs to be replaced
Posted on May 18, 2010
Mc 2000 es
please see the video attached. and lube too the rollers bearing front+back. Test the drive belt motor fro crack, tight or replace it.
Test the output voltage from control board, for input voltage motor.
if there are OUTPUT voltage from control board, this is a o.k the motor is faulty. and viceversa. See my personal TIPS for help.
God bless you
Oct 01, 2013 | Proform Crosswalk 500 Treadmill
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
I have proform CT 400 treadmill, belt does move. motor seems to be frozen, on control board red light blinks twice then stops and after few seconds blink again twice. Incline and every thing else work
Dear Sir:1) Lube the deck belt, maybe you have a deck belt worn, and need replace.2) Test the input voltage for main motor, if there are the motor need repair or replace.3) Test the output voltage from main board for input voltage motor, if there are NOT, the board is faulty.4) See the drive belt and replace it.See my personal tips for HELPsincerely. God bless you
May 03, 2012 | Proform Exercise & Fitness
I was walking on it and it just stopped. The panel still works but I can't hear the motor running or anything. It's almost like it's not even on
The single most cause of no belt movement is failure of the DC motor control. Unplug the unit and remove motor shroud and look for any test lights on the power boards beneath the motor hood.
If you have a multimeter, you can test to make sure you have DC output from the controller spades. First make sure you have 120 VAC going in to the controller. On most controls, you can use a linear taper potentiometer or jump the W and H circuits of the control with an insulated wire or insulated pliers and apply AC voltage. The DC output spades should output DC voltage if the control is good , if it fails this test then motor control will need replacing.
One more test needs to be done to rule out the motor:
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. this process can be done with a car or lantern battery you will get the same results.
Jun 28, 2010 | Proform Crosswalk 3.0 XT Treadmill
I can turn everything on but the belt does not move. I used it one morning and then that evening it would work
The single most cause of no motor output is failure of the DC motor control. Before you attempt to determine if it is the control, you must first rule out simple things.
1) Make sure you have power in the wall outlet by plugging in a lamp, etc. into the same outlet the treadmill is plugged into to test. Plug it in the exact same receptacle. Sometimes in an outlet one receptacle will work and the other won't.
2) Make sure any breakers are fuses that may have tripped or blown have been reset or replaced. Your local Radio Shack can help you test the fuses. Use the same type of fuse. Changing the value of the fuse can be dangerous or cause a fire.
3) Make sure the power switch is turned on and the safety key is inserted into the console if you have a safety key.
4) Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
5) Test for a motor control failure. Typically if you have a failure, the treadmill will continue to turn on and operate normally until you try to input speed. If the treadmill operates on what we call a closed-loop system, it will give you some type of error message. If it operates on an open-loop system, the computer will run normally but the motor will not turn.
6) If you have a multimeter, you can test to make sure you have DC output from the controller spades. First make sure you have 120 VAC going in to the controller. On most controls, you can use a linear taper potentiometer or jump the W and H circuits of the control with an insulated wire or insulated pliers and apply AC voltage. The DC output spades should output DC voltage if the control is good.
7)
Jun 27, 2010 | Nordic Track Nordictrack Apex 4100i...
I have a v-fit PST-04 treadmill, model no DK 2510. When I switch it on and try and use it, it comes up with the Error Code E1 what does thos mean
Most E1 codes are speed sensor or no belt movement.
You wil lneed to unplug your unit the remove the motor shroud then plug unit in most Motor Control boards have LEDs. First thing I would do is start the unit look down at the board one of the light should start flickering this is a signal being sent to the lower board from your upper console. This tells me that the upper console and cable connecting the upper and lower boards is working also notice if the drive motor moved if not then E1 will come up. Now turn your unit off then turn back on to reset , next manually push with one of your feet the belt you should notice another flickering light the faster you push the light will flicker faster this tells me that the speed sensor is working if not replace the speed sensor. Next procedure check the motor using a fully 18v drill battery or car battery which ever is handy connect the two motor leads usually red and black in some cases black and white to the battery, if the motor move at a speed of approx. 1 mph then you have a good motor if not you can have worn motor brushes or open winding the motor.
If the upper board and drive motor are good then the only thing left is the motor control board if you have a multi meter handy connect the lead to the two spades that motor lead came off of the press start you should get a DC voltage of about 5 to 10V DC if not replace the board.
May 31, 2010 | Exercise & Fitness
Motor tries to start and then stops and will not try to run again. If I turn it off and back on it will do this again. I tested cirucit breaker button and this is not the problem. Checked belt tension and...
If you have a multimeter, you can test to make sure you have DC output from the controller spades. On most controls, you can use a linear taper potentiometer or jump the W and H circuits of the control with an insulated wire or insulated pliers and apply AC voltage. The DC output spades should output DC voltage if the control is good test the drive moter, if not replace controller. The next thing to check if controller is good is the drive motor. Using a 18v drill battery ( fully charged ) or a car battery which ever is easier, attach the drive motor connectors to the battery and it should start to rotate at 1 mph if not then replace drive motor.
May 25, 2010 | Proform 730 Folding Treadmill Model...
Not start
The single most cause of no motor output is failure of the DC motor control. Before you attempt to determine if it is the control, you must first rule out simple things. 1) Make sure you have power in the wall outlet by plugging in a lamp, etc. into the same outlet the treadmill is plugged into to test. Plug it in the exact same receptacle. Sometimes in an outlet one receptacle will work and the other won't. 2) Make sure any breakers are fuses that may have tripped or blown have been reset or replaced. Your local Radio Shack can help you test the fuses. Use the same type of fuse. Changing the value of the fuse can be dangerous or cause a fire. 3) Make sure the power switch is turned on and the safety key is inserted into the console if you have a safety key. 4) Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged. 5) Test for a motor control failure. Typically if you have a failure, the treadmill will continue to turn on and operate normally until you try to input speed. If the treadmill operates on what we call a closed-loop system, it will give you some type of error message. If it operates on an open-loop system, the computer will run normally but the motor will not turn. 6) If you have a multimeter, you can test to make sure you have DC output from the controller spades. First make sure you have 120 VAC going in to the controller. On most controls, you can use a linear taper potentiometer or jump the W and H circuits of the control with an insulated wire or insulated pliers and apply AC voltage. The DC output spades should output DC voltage if the control is good. Next thing is to unplug the treadmill then check the motor with one these methods
Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. 3) Lantern battery- a fully charged lantern battery should operate your motor at a slow speed but lacks the amperage to have someone walk on the belt. 4) If you have a multi meter and you don't have any of the three mentioned above, then disconnect the motor leads and connect them to the meter.Lay the meter down to where you can observe it. Push the running belt what happens is that the motor is now a generator and by manually pushing the belt you should get a DC voltage reading( the fast you push the higher the reading) then the motor is good if no reading the motor needs to be replaced
May 21, 2010 | Proform 775 Crosstrainer Treadmill - Free...
Belt will not start up and move.
The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity ( capacitors are charged) in the motor area even if the treadmill is unplugged.
If you have a multimeter, you can test to make sure you have DC output from the controller spades ( Drive Motor Connectors) by clipping on them and then pressing the start key you should have a DC voltage reading if not the controller board is defective.
The motor can be tested by using a simple DC cordless drill or lantern battery this will turn the motor if the motor is good the controller board will need replacement , if not their won't be any belt moment the problem is the motor then the motor will need to be replaced. ( if you don' t have a multi meter this method of testing simple and easy)
May 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Sounds like that there is a short in the control board.
Mar 23, 2010 | Reebok Rt1000 Treadmill Walking Belt
Reebok Rt1000 Treadmill Walking Belt Logo
294 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
