Question about Desa International White Wireless Plug In Door Chime
JUMPER SETTINGS FOR SL-6151-RX-A
I lost my pin setup for my doorbell and my neighbor installed the same model.her doorbell is ringing mine.where can I find the setup for the jumpers for model SL-6151-RX-A
    Problem Solver:
  • 9 Answers
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
Posted on Nov 10, 2011
Why does chimes sound when no one as pressed bell
water can get into the button on door inside is a spring that pushes a part of the switch away from the other and when someone presses it they join together and bell sounds but if the rain gets inside it can make an electrical connection between the two points open it up and see if there is any trace of water the just put a bit of pva glue over the top join on the switch it will water proof it and will also be easy to remove or it could be a low battery or if mains anything can set them off mobile phones tv any thing that sends a rf signal its best to have as small a gap as possible between the two units
May 20, 2010 | Desa International White Wireless Plug In...
I have a wireless SL-6151-RX-A door chime and it does not ring
Check that the dipswitches on the button and the reciever doorbell unit match. Also verify that your battery is not installed the wrong way.
Nov 15, 2009 | Desa International White Wireless Plug In...
My bell rings when my neighbor pushes his button and vice versa how do you correct. Model SL-6166-RX-A purchased at home depot.
Take the back off the 'bell' and you will see two rows of gold colored pins running parallel to each other, eight pairs I think. Three of these pairs of pins will be covered by jumpers. Jumpers connect two pins together.
Pull any one of these jumpers off it's pins and move it to any other pair of pins.
Make note of which jumper (the pins are numbered) you moved and to which pins you moved it.
Now, take the cover off the 'button'. You will see an identical set of jumpers and pins to those in the 'bell'. Duplicate there, the change you made to the 'bells' jumpers.
Ghost rings solved!
Ok, ok, on the wild outside chance that the problem persists, just move another set of pins.
Remember, the jumper configuration in the 'bell' and 'button' ' must be identical.
Nov 04, 2009 | Desa International White Wireless Plug In...
Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Aug 31, 2009 | Desa International White Wireless Plug In...
SL-6195-RX seems three houses have the same
Open up both the button and the main unit and switch the codes with the pins. It done on a row of pin sets - Default is usually connectors on 5-6-7 (8 is on the main bell unit and causes the ding-**** to change to a Westminster chime).
With a pair of needle nose pliers pull the connector and set them on different numbers. You must do this on both pieces, When you have a unique code its no longer an issue with the neighbors.
Aug 02, 2009 | Desa International White Wireless Plug In...
I'm looking for push button for a trine/desa model #SL-6166-RX
I believe this is also the Zenith door chime. I bought mine at home depot, and they have the push buttons.
Mar 01, 2009 | NRS Huge Playhouse W/ Kitchen, Skylight,...
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Dec 29, 2008 | Desa International White Wireless Plug In...
My pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
Desa International White Wireless Plug In Door Chime Logo
3,109 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Steven R
Julian Pearson
Level 1 Expert
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
