Question about Sony Handycam CCD-TRV318 Camcorder
My screen My camera will playback the videos through the eye and the door with the sreen built in.But when i try to film isee nothing through the eye and side screen just a screen that looks the same all the time..like a blank wall.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 12 Answers
    Genius:
  • Sony Master
  • 1,691 Answers
If the camera can record images, and they do not show in the viewfinder while the recording is being done, the fault may be the following:
My answer will be generic to almost all video cameras in general.
On the circuit board where the viewfinder control is done, there is an IC and some electronics for this process. It is possible that this IC or something in the related circuits is not working properly, or there is a bad ribbon cable, or a cold solder connection.
The first thing to do before bringing the camera for service, is to check the menus if you can see them. Make sure that there is no option turn on in order to use an external viewfinder while the camera is in the record mode. If you cannot view the camera setup menu check for a mechanical switch on the side, or back of the camera, or in a compartment for this option. If all else fails, then there is a fault condition.
Also read through the instruction manual, and through the fault sections.
Jerry G.
Posted on May 02, 2008
SOURCE:
Google Android 4.1 OS 1.2GHz 4GB 7" Tablet PC black sreen
Try pressing the power button for 10 seconds. That shoult restart your phone.
May 17, 2014 | Google Android
Where do I go for service?
If the videos that show poorly were stored near a source of magnetism that may cause problems. If some work perfectly it is probably not the recorder. Try a test with anew cassette-record and playback, Unsure how to get faulty ones repaired if possible.
Jul 17, 2012 | Sharp Video Cameras
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
Can't get rid of the screen images for video camera on playback
Hi
If it's like my Canon MVX25i date and time marking then go to the menu, select display setup (or whatever it's called on your camera) somewhere there should be a dialogue which allows you to switch the pesky thing off. I have never used date or time, a very amateurish concept in the first place.
Redars
Scorpigirl
Apr 15, 2009 | JVC GZMG435AG Camcorder
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is [email protected] and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Playback
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Can not playback past end of first file on my Panasonic PV-GS2
I'm not sure if this will work for you but, sometimes I try to play back some of my tapes and a blue or grey screen comes up instead, although this sounds odd, if I record something(for even one second) it will let me see my film. I know this can cause problems because you may end up taping over film but if it's the only way to see your film it's worth a try!
Jun 02, 2006 | Panasonic PV-GS2 Mini DV Digital Camcorder
Sony Handycam CCD-TRV318 Camcorder Logo
73 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
