Question about Bodycraft Galena Home Gym
I need A new cable as the cable broke - Bodycraft Galena Home Gym
    President:
  • 832 Answers
All Bodycraft @1-800-990-5556 or go to www.bodycraft.com
Posted on May 23, 2010
I need A new cable as the cable broke for "Pacific Fitness Malibu Home Gym"
call the manufacturer for a replacement
find a cable , chain or lifting apparatus shop in your area and using the broken cable as a sample have a new one made
Nov 24, 2016 | Exercise & Fitness
I need a usb port to be soldered to my motherboard, and a speaker cable from MB to connection by the DVD
Do not try the repairs, insert a USB card instead.
The advantage is that you can upgrade to USB3.
Install a new sound cable.
For the video card, Ebay.
Aug 15, 2015 | Computers & Internet
Cable connection in TV broke off
That part is soldered into the TV circuitry. Chances are that a TV repair professional will need to open it up unless you know someone that knows how to desolate and solder in a new plug. If the circuit board is damaged, then you will have to source a new part.
Oct 20, 2014 | Seiki 32" LED TV - SE321FB
How do i fit a new throttle cable to my volvo V40 2001 model?
On Youtube, search for "throttle cable replacement volvo". It might help.
May 14, 2014 | 2001 Volvo S60
Control cable broke push and pull broke
Remove the handle assembly by removing screws and sliding off. Remove nozzle housing cover and unscrew fastener at end of cable. Pull cable from handle end out of cable sheath. Slide new cable into sheath and fasten at bottom as it was before. You will need to adjust the cable to the proper location so the transmission works properly in both directions.
Apr 18, 2014 | Hoover Self-Propelled WindTunnel Bagless...
How to fix shifter cable on 2004 pontiac montana van
order a new cable! if it's actully broke! can't fix broken cables just have to put new ones!
Sep 03, 2012 | Pontiac Cars & Trucks
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
I own a 1981 suzuki gs 850. the bikes clutch cable broke the other day as i rolled up to a light and shifted it into neutral. i put a new cable on the bike and when i pull the clutch and shift into 1st...
Yes.Because your old cable was old,it had stretched.New cable has been put on and the adjustment of it is wrong.It needs to be readjusted.If the bike sat around for a long time after the cable broke(and you said it did not) then a different problem may exist.Get the clutch readjusted and all should be good.Hope this helps
Aug 31, 2010 | Suzuki GS 750 Motorcycles
Hi, I have a 1999 Camry LE 4-cylinder automatic. The car is not shifting into gear. I popped the hood up and noticed that the transmission control cable (shifter cable) connection to the neutral saftey...
I think the cable is molded into the little plastic piece. see if you can see the end of the cable. see if it looks like it broke, or was cut. if not, the molding came undone, and the cable pulled from the anchor in the plastic thing.
Aug 15, 2010 | 1999 Toyota Camry
Bodycraft Galena Home Gym Logo
165 people viewed this question
Top Bodycraft Exercise & Fitness Experts
Howard
Howard
Jay Plesset
Bill Boyd
Are you a Bodycraft Exercise and Fitnes Expert? Answer questions, earn points and help others
