Question about Dometic RM2652 Refrigerator
I need to know why my Dometic RM2802 will not operate on the gas side
  • Dometic Master
  • 6,674 Answers
Does it try to ignite at all? Have you checked for 12 volts at lugs near bottom of fridge at back (remove cover outside) ? Pull cover on control box and check for blown glass fuse as well. Let me know what you find. Unplug it from receptacle when testing, and checking for fuses.
Posted on May 22, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Dometic 2652 cooling on gas but not on a/c
No AC operation
- operates on gas mode
Operation
AC Volts
Fuse
Heating Element
Wiring
Lower Circuit Board
Jul 03, 2011 | Dometic RM2652 Refrigerator
Need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jun 08, 2010 | Dometic RM2620 Refrigerator
My dometic refrigator stopped working but it works good on propane not electric
May just need new heating element. Need to check for 120VAC, coming from connectors on circuit board to element, if yes, change element.
Make sure it's on AC operation, and calling for heat, you may have to leave door open on fridge, just to make sure it's calling for heat, or try on gas, if it lights, then you know it's calling for heat, then switch to AC operation and check for the proper voltage to element. If you need more instructions, let me know.
Apr 11, 2010 | Dometic RM2620 Refrigerator
Hello. pages 13 and 14 in this manual lists all of the possible reasons why the gas side in a Dometic will not operate http://www2.dometicusa.com/pdf/822709100%20MO-FO%200248.pdf Joe
Mar 23, 2010 | Dometic RM2652 Refrigerator
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
The system is sealed very difficult to charge. Not to mention expensive. The same price to get a new coil. The boards that control the operations are hard to trouble shoot sometimes. Do you have 12 Volts DC going in to the control board. If yes does the control board inside show green lights that it is working. If so the lower control board on the out side needs to be looked at.
Sep 04, 2008 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
333 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
