Question about InFocus ScreenPlay 5700 Multimedia Projector
Plays for 1 hour and bulb shuts off and it says tring to restart
It restarts for 5 seconds and the unit fan shuts off and it shuts of and read out says tring to restart please wait.leave sit for 10 to 15min.and still says same thing and push power on again and plays for short time and shuts off again .after leaving off you push power on again then only green shows no color.filter is new and clean and vents are clear
    Champion:
  • 269 Answers
Likely the power supply/ballast.
Posted on May 18, 2010
Hey,i got my 2nd hand xbox360 .i wan playing like for 5 hours then i closed for 2 hours then i play again within the 1 hour is freeze and i restart and i got the RROD
Either. a) Put a towel over the xbox and let it run for 5 hours. Then restart it.
Or b) call 1-800-4myxbox to get it shipped in and fixed
May 11, 2011 | Command & Conquer: Red Alert 3 Sealed for...
Turns on and runs for 2minutes and shuts off
Hi, Did you buy it new? How many hours does it have on it. I have a Sharp projector for which I bought a used bulb which started for 1 - 2 mins then shut off. Restarted a minute later then shut off again. I bought a new bulb and that solved the problem. It could also be a weak ballast if the bulb has low hours or if the filters are dirty, it could overheat and shut off. Make sure the filters are clean and the cooling fans are running and the unit has good ventilation.
Hope this helps,
Feb 19, 2011 | Radio Shack Cinego D-1000 Multimedia...
I noticed an unusual high pitch sound which I traced back to the refrigerator. I then noticed that the front panel lights were flickering on and off and so was the external ice maker lid. I turned the...
Hi and welcome to FixYa, I am Kelly. First off the high pitched sound you heard was most likely ice build up on the evaporator so th evaporator fan blades were striking the ice. Now as for your shutting of the unit and staring right back up..... You need to wait 15 - 20 minutes of OFF time when ever there is a power interruption. What is happening now is that the compressor can not restart because the coolant pressures are to high. That 15 - 20 mins of off time will afford that pressure stabilization time.
What you really need to do is remove the freezer contents and place a fan blowing into the freezer compartment to manually defrost the freezer evaporator. (about 2 hours of floor fan time) This should get rid of the high pitched noise. Then.... restart the unit. It should restart.
I suspect that you have an automatic defrost problem is why you had the noise. The manual defrost will only get you 2 - 3 days of normal operation again before it once again starts the icing routine. I want to get this off now to get you started on the manual defrost. I will respond with a 2nd post about the defrost problem.
Your to do list...
1. unplug the unit.
2. Manual defrost with floor fan (2 hours of fan and water mess)
3. Restart the unit
4. Watch for next post about defrost.
Thanks for choosing FixYa.
Kelly
Dec 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
MY PANASONIC PT-50DL54J DLP will just turn off. I
I have posted solutions for similar problems.
There may be a heat issue with the power supply components.
Remove the back panel and blow compressed air into all the component area, (except the fan on the right). The power supply is on the left.
Then vacuum all the dust out.
There may be a problem with the battery in the remote. Weaken batteries can cause the remote to send random signals (including turning off the set).
Aug 22, 2009 | Panasonic PT-50DL54 50" Rear Projection...
I have a projector (SONY VPL-ES1) and the bulb stopped working. Took the bulb out, and not sure if it's blown or not. I checked online, to see if anyone else had similar problems, and sure enough they...
usually the projector powers and cools down. if you restart it it will open the cover, not projecting anything and after 10 seconds it will close again. this happens if the lamp is shortly before the end of the measured lifetime (no fixed hours) to protect the projector. usually if you take it out once or twice it will work for 1 or 2 more times but the bulb is very likely to explode (not destroying the projector but not good anyways)
Dec 30, 2008 | Sony VPL-ES1 Multimedia Projector
InFocus ScreenPlay 5700 Multimedia Projector Logo
137 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
