Question about OKI C9300 Led Printer
Label Printing How do we configure the printer to print standard labels, size 2" X 4"?
    Problem Solver:
  • 15 Answers
The printer is not the issue here...That is a great printer BTW.
The issue is which program are you using when trying to print out these labels? Do you have Microsoft Word, Works, or some simular word processor program installed on your computer?
There are free document templates that have all the settings for printing 2 x 4 labels and others. Here is a link for a 4 x 2 tem-late that would work in any version of Word, SureThing CD Labeler and any program that handle PDFs.
You can take label printing to the next level by using a program that will read in your address book and print each on one label automatically. You don't spend time trying to type them all in.
If yo have MS word, look under HELP for "mail merge", that wil get you on the right track.
Let me know =)
Posted on Mar 31, 2008
Zebra Printer prints incomplete Label.
Run a config label and see if you have the same issue. Power it up while holding cancel key is the easiest way to do that.
Oct 28, 2015 | Zebra Z4Mplus Label Printer
All labels are printing at a reduce size how do I change?
Hello there,
You normally configure a label size from 2 places:
a) Printer Driver(I reccomend downloading the one from Zebra from
b) Directly from Printing software option
In both cases, search for the "Genera"l tab and you will be able to configure the label size
Jun 09, 2014 | Zebra 105SL Thermal Label Printer
Printing on edge
Your software label template does not match the size label your printing on. Make sure your label size IE: 2.25" x 1.25" matches the template size in the software, then perform this calibration:
TLP 2742 is printing blank labels
Apr 19, 2014 | Zebra Eltron LP 2824 Thermal Printer
At school there is a printer the Dell 5100cn laser printer and we need to print labels and each time we try it asks on the computer if I want to continue because they are outside of the standard margins,...
A5 is a European paper size standard. Your label making program is telling the printer that the program needs that size label paper. You have to tell the printer to use that size paper. It may be somewhere in the menu of the printer driver on the computer or it may be on the display window on the printer, or it may be as simple as flipping a tab in the paper tray. As far as the printing outside the standard margins, most printers will allow a certain amount of that without a problem. Just tell it yes or Ok. If you solve the paper size problem and it hangs up when you tell it to print outside the margins, then the printer is not compatible with that label format in the label printing program. You will have to choose a different format. I recommend that you select a label format that is a US standard like 3 across on 8 1/2 x 11 paper.
Nov 19, 2010 | Dell 5100cn Laser Printer
Label double print
It's possible that the printer did not get a good calibration on the size of the label. There's an optic sensor looking for the gaps in the labels. A test would be to turn the printer off and back on again. When it is ready, just press the feed key. If one label advances then the printer had a good read on the label size. The idea is to see if the printer works ok by itself first.
Now print a label - if you get two labels then you have to look at the software / printer driver as the cause. The printer will only do what it's told to do.
Hope that helps !
Apr 14, 2010 | Zebra LP 2844 Thermal Printer
My dymo label printer is printing 2 labels at a time. One has the label I want. The other is blank. Can you help me?
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Mar 24, 2010 | Dymo LabelWriter 400 Thermal Printer
I have an HP 5550 Series Deskjet printer. Only recently, I have encountered difficulty printing labels. I have double-checked the Printing Properties, including label size, label paper size, Avery paper #,...
This printer have the capabilites of sense the size of label, each colomn width.
So, you must set the right size of colomn width, in your application (ms. word) to match label width.
May this help.
Oct 10, 2008 | Office Equipment & Supplies
Easy coder
Switch off the power. Hold down the Feed button while you switch the power back on.
After the Configuration label prints, turn the power off and on again, then try printing again.
Aug 21, 2008 | Intermec EasyCoder PC4 Label Printer
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
OKI C9300 Led Printer Logo
118 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
